Tuner woes.
Old April 20th, 2008, 11:41 PM   #1
RAGEman's Avatar
1965 Mustang Fastback
N/A
RAGEman will become famous soon enough
Tuner woes.
First and foremost, I just installed LT's and an O/R mid-pipe, and I thought that I could program the car and that would take care of the SES light without the use of MIL's. My light went off for about a day, but came back on today. Do I need MIL's? If not, what variable do I need to change for tuning.
Old April 20th, 2008, 11:42 PM   #2
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
which tuner do you have?
Old April 20th, 2008, 11:48 PM   #3
RAGEman's Avatar
N/A
Sct Xcal3
Old April 20th, 2008, 11:49 PM   #4
13.00 @ 105
got ya... cant help you there, I've never messed with one of them!
Old April 20th, 2008, 11:57 PM   #5
neverfastenough1's Avatar
I know my livewire asks you if you have rear 02 sensors in the user options part of the program. Is it the same for yours?
Old April 21st, 2008, 12:45 AM   #6
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
what tuners do allow you to eliminate the rear o2s, Im thinkin bout gettin a full system myself.
Old April 21st, 2008, 12:50 AM   #7
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
Does your xcal have a custom tune with your LTS and o/r x. Once i loaded my custom tune that had the 0/r x my ses light went off perm. before that the pre loaded tune i could turn it off for maybe only a day before it triped the ses.
Fire it up, burn it down.
Old April 21st, 2008, 04:20 AM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Got to go under the change parameters section and actualy turn em off. You can also remove the speed limiter and change gear ratios in there, plus a few other things.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old April 21st, 2008, 07:21 AM   #9
RAGEman's Avatar
N/A
So the rear 02's need to be turned off?
Old April 21st, 2008, 07:26 AM   #10
tom2000r is on a distinguished road
yes
Old April 21st, 2008, 07:35 AM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Originally Posted by tom2000r View Post
yes
+1 You can do it easily thru the X3. I can walk you thru it if you need.
Military Crew
U.S. Army Aviation
Old April 22nd, 2008, 01:55 PM   #12
Trick Tuners's Avatar
KB'd GT
I can custom tune your car for the LTs and turn off the rear o2s in the tune.
Old April 22nd, 2008, 03:06 PM   #13
Blown 03 GT
you wont pass inspection with the rear o2 removed will you?
Old April 22nd, 2008, 03:53 PM   #14
KB'd GT
I doubt it, but it probably depends on your state rules.
Old April 22nd, 2008, 09:27 PM   #15
RAGEman's Avatar
N/A
About that, I think AM was supposed to do that, but I don't think they did. When I choose to view the variables on the Custom tune, everything appeared stock. I have 3.73's and it showed them to be stock, and the rear 02 sensors were on as well.
So, I ended up changing those 2 variables myself, but other then that, I left everything else stock.
Did I gain any power? Is that all that you would do? If you can manage to squeeze more power out of it, I would be more than happy to purchase a tune from you. Without going into detail (don't what to give away your tuning secrets) what kind of things can you change to increase HP?
Old April 22nd, 2008, 09:43 PM   #16
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
They probably sent it without the tune. You loaded the custome tune or the preloaded tune?
Military Crew
U.S. Army Aviation
Old April 22nd, 2008, 10:46 PM   #17
RAGEman's Avatar
N/A
Originally the custom tune, but when I looked into the tuning variables, nothing was different then stock. So, I went into Pre-Programmed tunes, and created my own. I changed the variables myself.
Old April 22nd, 2008, 10:51 PM   #18
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Well in that case yea a custom tune is gonna make a difference.
Military Crew
U.S. Army Aviation
Old April 22nd, 2008, 10:54 PM   #19
RAGEman's Avatar
N/A
I appreciate it.
Trick Tuners, You've got mail.
Old April 23rd, 2008, 11:05 AM   #20
KB'd GT
Making hp is easy, most tuners can tune for WOT without issues. The only factors that adjust hp are the AF ratio and the timing values. I specialize on making the car run correctly at all throttle positions. PM sent.
Threads Similar to: Tuner woes.
Longtube woes. RAGEman 99-04 17 March 31st, 2008 11:48 PM
Seatbelt Woes. RAGEman 99-04 13 December 7th, 2007 07:42 AM
CD player woes 06RedfireGT 2005 - 2010 40 July 10th, 2007 01:34 AM
Air Bag woes GreenFaleen The Clubhouse 18 April 27th, 2007 12:30 AM
