Mach 460 Head Unit
I have a Mach 460 system and I want to replace the head unit with an indash GPS/CD unit. Will the whole system still work if I don't have a Mach head unit anymore?
The Mean Green
Yea it should, I think most people swap em out anyway. I have a Kenwood deck and all my speakers work.....except for that blown one
Hope it still works because after Father's Day I am putting my new double din Kenwood in. Its going to be a suprise.
RLY SRS
Here is a link Im sure most you guys can dig...
Integrating AM Head Unit w/ Mach 460 (00-04 Mustangs) - Mustang Forums
![]() Mods Include...... BBK CAI MM Caster Camber Plates Baer Decalla Drilled and Sloted Rotors w/ painted callipers Hypercoated 18x9 FR500 Rims Eibach Pro Kit Lowering Springs More to come.....! |
#6 | |
2001 Mustang GT
UNKown
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 |
Hey chris, is your unit flip down. Or does it just stay there?
2002 GT SOLD 2003 Mustang GT Cobra Clone SOLD Procharged @ 8psi 458 rwhp ![]() Mods in Garage
2001 Mustang GT
UNKown
I can tell the unit stays there .Its a double din unit.
I want to get the flip down. Any advice on which one? The thing is that the ones that stay there are attractive to thieves here in P.R LOL
Is there one were you can run your engines stats on?
RLY SRS
Yeah the one i have you can intergrate a vehicle control deal into...
2001 Mustang GT
UNKown
2001 Mustang GT
UNKown
Question for you guys about your aftermarket head units and the METRA - 70-5521 harness.
Q.Does your front and rear fader still work ?
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 Last edited by RanGer498; April 27th, 2008 at 04:31 PM. |
RLY SRS
Sure does...
2001 Mustang GT
UNKown
RLY SRS
Mine had 2 I thought...
2001 Mustang GT
UNKown
bumpz
2001 Mustang GT
UNKown
2001 Mustang GT
UNKown
I have the mach 460 audio sysytem in my 2001 mustang gt and im a little confused on some parts from this thread.
Integrating AM Head Unit w/ Mach 460 (00-04 Mustangs) - Mustang Forums 1)the part where it state "Take the 2 Black/white amp grounds on the RCA plug harness, and solder these, plus your dimmer/illum. ground (orange/black)and solder them to the metra adapter ground along with your radio ground, " Do i take black and white (amp ground) wires AND the orange/black (dimmer/illum. ground ) wires and solder them all together to a new chassis ground or do i solder them all to the one black ground on the Metra black harness and to the factory harness? 2)also do i wire up all the wires for the speakers as well or do i just use the rca cables to get sound from my new head unit? im thinking i just need to use the rca cables and not wire up the speaker wires ,is that correct? asking since i dont have my new head unit yet to test anything and want to get my mind ready.
#20 | |
2001 Mustang GT
UNKown
what i did was : 1)Take the 2 Black/white amp grounds on the metra RCA plug harness, and i took the dimmer/illum. ground wire (the orange&black wire ) from the metra harness and solder them togther and put them all on the chassis of the vehicle with a screw from under the dash thats on the metal frame of the car ,i soldered the radio ground wire to the metra adapter(black) ground wire. so far i have no ground loops or whine noise. 2) all the wires front,rear,left,right from the aftermarket head unit also had to be solderd on to the metra harness for all the factory highs to work ,i put the from the metra harness to the front rca jacks from the new head unit as it gave me the best over all control of the audio system. NOTE: the fader will still work but it will work a little odd due to the way the factory mach audio system wires are set up .
Threads Similar to: Mach 460 Head Unit
| Mach 460 Head Unit Swap Issues | SVrider | Audio/Video | 9 | February 8th, 2008 04:26 PM |
| 99 Mustang w/ Mach 460 And New Head Unit Pls Help | bubagump17 | Audio/Video | 3 | December 15th, 2007 10:23 AM |
| How to replace the mach 460 head unit? | mustangmanic | 99-04 | 13 | July 18th, 2007 01:13 PM |
| MACH 460 System... replacement speakers? Head Unit??? | Slowbra_12 | Modular Mustangs | 1 | May 30th, 2007 01:35 AM |
| new head unit help | Pharoh | Audio/Video | 6 | February 3rd, 2007 12:09 AM |
