![]() ![]() ![]() ![]() ![]() iTrader: 13 reviews
My Engine life
My car has 62,000 miles on it. I know our motors can handle a lot of miles but im just wondering when the power will start to fade due to Wear and tear? I would like to have my car for a very long time till it dies or it still looks like a beauty. But i just don't want to put a bunch of money into it and then a couple thousand miles later the engine is starting to go. I am not the original owner so i have no idea how the previous owners took care of her but i know i take care of her. So what can i do to see how the motor is doing? Is a compression test a good start?
MM's nicest mod, :)
yes a compression test, but you really never know when i motor will go. Whats more than likely going to happen is your gonna spin a rod bearing. Just don't know when that time will come, do the basic routine maint on the car and hope for the best. If your motor runs fine now don't worry about anything, i doubt your gonna have any problems anytime soon. Enjoy your car instead of being mr worry worryington lol
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
haha yeah im a worrier. Well thats good to know then. my engine seems to be running in top condition. No problems. ill probably run a compression test then just to know how its doing.
So whats considered a good compression reading, bad number/good number?
MM's nicest mod, :)
if they are all reading close to the same then you are good.
hmm ok, easy enough
MM's nicest mod, :)
i am not going to tell you it should be at 170 cause if they are read 155 your gonna flip out you little worrier you. So if they are reading about the same give or take your fine
change the oil and keep it off the rev limiter and it will last a long, long time.....
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
just dont bash it around everyday like a young punk with no sense
Threads Similar to: My Engine life
| How much life can you get out of a 4.6 | 86ttops | 96-98 | 15 | April 13th, 2008 10:56 PM |
| my life is becoming sad | thorpedo26 | The Clubhouse | 74 | March 23rd, 2008 05:02 AM |
| a day in the life of Zip. | HMUSN | The Clubhouse | 3 | February 19th, 2008 08:34 PM |
| sad life of.......... | WilltheThrill | The Clubhouse | 3 | November 30th, 2007 07:06 PM |
| Ah this is the life | 06RedfireGT | The Clubhouse | 3 | November 4th, 2007 11:44 AM |
