Nitrous woes
ok well i just went and did a test run with the 100 jets and its nuts, however i have a stumble at engagment and then it straightens out. i called NX to see what can be done to remedy that problem and they have an accumalator for 216 bucks. i dont want to take this route but will if need be. Will to pumps remedy this and how would one go about setting up a twin pump system.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
N/A 4v Guru
2003 Mach 1
I would datalog the nitrous run and see what the stumble realy is first. Your fuel system is good enough to hold what you have and the 100 shot easily. I would almost bet the stumble is the delay in the N20 hit and it is pig rich for a moment. Check it out on the datalog and see.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
cool good idea now to get my xcal to work with vista
, i might try upping my engagement rpm to 3500 too.
2001 GT
do you have good bottle pressure ? you need a minimum of 900 for things to work properly
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,443 RWHP/ 386 TQ |
pressure is good, full bottle, a ran it last night and it didn't seem to do it as much.
Cigar Assassin
do you have a purge on the system?
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
heater, purge, window switch, you name it
MM's nicest mod, :)
you might need a boost a pump, if you have a fpss then for just a split second its probrably seeing a drop in fuel pressure and shutting the nitrous off. Mine did that on occasion but not too often, i just adjusted the fpss to compensate for the quick drop since mine was set to cut off around 25psi.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Threads Similar to: Nitrous woes
| Longtube woes. | RAGEman | 99-04 | 17 | March 31st, 2008 11:48 PM |
| Seatbelt Woes. | RAGEman | 99-04 | 13 | December 7th, 2007 07:42 AM |
| CD player woes | 06RedfireGT | 2005 - 2010 | 40 | July 10th, 2007 01:34 AM |
| Air Bag woes | GreenFaleen | The Clubhouse | 18 | April 27th, 2007 12:30 AM |
| Contour Woes... | WVSNS& | All Other Vehicles | 7 | April 10th, 2006 03:35 PM |
