2000 mustang gt
02 wire
i have my lean cut off switch for my nitrous all hooked up exept for 1 wire. the purple one that goes to the 02 sencer. when i looked under the car there are four wires from each 02 witch one do i connect it too? or witch one is the sending wire?
2000 mustang gt
no one knows
2000 Mustang Gt
![]() Look at the picture of the o2 plugs. Ours should be the same as the 96-97. I'm not sure if that helps you or not.
![]() Tuned by Joe at Tricktuners.com |
On the driver's side front sensor the sensor signal+ will be the red/light green wire, on the passenger side front sensor it will be gray/light green--with OEM sensors.
With most all aftermarket sensors the two white wires are the heater power, the gray wire is sensor signal ground, and the black wire is the sensor signal+...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2000 mustang gt
i figured it out it was the black wire. there was a black wire a white wire and two gray wires. i think my o2s are stock
Not with those colors, the OEM sensors always have pretty color wires; with different color signal + wires at each sensor...
Threads Similar to: 02 wire
| o2 wire problem | supercharged03gt | 99-04 | 1 | January 11th, 2008 08:16 PM |
| tach wire | mongo | General Tech | 3 | July 3rd, 2007 12:16 AM |
| which wire? | VSR13 | V6 Mustangs | 5 | May 24th, 2007 02:46 PM |
| Phantom wire | Blackblurr_00GT | Modular Mustangs | 2 | April 3rd, 2007 09:06 AM |
| help with sparkplug and wire | 95 mustangmiz | V6 Mustangs | 11 | March 20th, 2007 12:45 AM |
