LinkBack (1) | Thread Tools |
#1
Drag wheel tire combo?
I have a small question. I have a set of summit drag wheels that are 15x8, and the biggest DR I can get for it is a 275/50/15. I was wondering if that would stick well enough for me at the track.?
Right now I have MT 15x10.5x26 et streets dot slicks with only 10 runs on them. How far could I drive on these tires? I want to get some dr's with some matching skinnys that I can drive to the track and race, then drive home on them. The thing is I live 90 miles from the closest track.. I though stepping up to a 15x10" summit wheel, and selling what I have now but the 15x10's won't ship until June the 2nd.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
MM's nicest mod, :)
those tires will be fine, and you can drive 10k miles on those et streets if its dry.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
#3 | |
You're talking about the bias ones correct.
MM's nicest mod, :)
i am talking about et streets, not et drag radials. ET streets are dot approved and you can drive on them, they are fine. just don't drive them in the rain cause then they are going to get you killed
Proud American
Can you really get 10K out of the tires? I know in the rain they are fun....
#6 | |
what back spacing would you use?
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
2002 gt supercharged
5.5" on a 15x8" wheel, and 6.5" on a 15x10"
2001 mustang bullitt
this is a stupid question but a 15 inch wheel will fit on our cars,i was told it wouldn't.
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. |
who told you that. and yes youll be fine driving 200 miles round trip on those as long as the roads are dry. like tim said, if its wet, your gonna kill yourself. and they will hook a lot better than your drs
N/A 4v Guru
2003 Mach 1
Might wanna make sure you inflate em a little or they will build heat quick on the road. Are you running tubes in your ET streets?
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#13 | |
I was going to run about 30 in them and I'm running them tubeless.
i wouldnt run that much pressure in them when doing a lot of highway driving. id say run around 25psi, and when you get to the track drop it down around 13-14 whichever works best.
MM's nicest mod, :)
yeah cause there is nothing funnier than seeing someone run around with 35psi in there et streets, it looks funny as hell. They look like they are gonna pop
Are you even able to tell the difference with skinnies? I know that they are lighter and less friction, just curious.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
#17 | |
I hear it's like 2 tenths in the 1/4
I heard that too, thought they were full of it
MM's nicest mod, :)
fats and skinnies work pretty good, just with a cat-back, pro 5.0 shifter, weld draglites with bfg drag radials i ran a 13.3. So they do make a bit of difference when combined with other parts
Did you not worry about breaking the rear end?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/68541-drag-wheel-tire-combo.html
| Drag wheel tire combo? | This thread | Refback | April 28th, 2008 10:53 PM | |
Threads Similar to: Drag wheel tire combo?
| thanks Sweet,,wheel and tire combo | tom2000r | Pictures | 8 | April 11th, 2008 09:22 PM |
| Tire Wheel Combo | JOHNNY K. | 99-04 | 6 | April 10th, 2008 11:20 AM |
| Wheel and tire combo??? | flamed 98 gt | 5.0 Mustangs | 0 | March 5th, 2008 11:57 AM |
| Tire and Wheel Combo | RandoGT | 96-98 | 10 | January 7th, 2008 05:30 PM |
| Front drag wheel and tire setup? | 03_StangGuy | 99-04 | 1 | July 29th, 2007 11:36 PM |
