COP's
Old May 1st, 2008, 12:44 PM   #1
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
COP's
Alright, I am just trying to rule things out when it comes to my car not running right. So from some suggestions of some i did a resistance test on my COP's. my haynes book says that the primary resistance should be .5 ohms and the secondary resistance should be 5.5K ohms.
I used my ohm meter and got the following #'s on my COP's:
1P - .8
1S - 5.5K
2P - .7
2S - 5.48K
3P - .7
3S - 5.49K
4P - .8
4S - 5.48K
5P - .8
5S - 5.59K
6P - .8
6S - 5.43K
7P - .8
7S - 5.44K
8P - .8
8S - 5.45
so what do i gather from this?
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old May 1st, 2008, 02:25 PM   #2
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
did your haynes specify a range for them to be within? i know, or at least whenever ive had to deal with somthing like this, there was always a specific range for it to be within... not just one value, i would think those numbers reflect that your COP's are fine... i would think
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old May 1st, 2008, 02:45 PM   #3
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
They are all well within spec--however, a low voltage resistance test (usually less than 1.0V with a plain ol' digital multimeter) only verifies that there are no dead shorts. To really bench test the secondary you'd need a high-voltage tester.
What do you mean by "not running right", it sounds like you are trrying to track down a skip or miss?
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old May 1st, 2008, 03:17 PM   #4
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
for the 96-98 it gives a range, but for 99-04 it gives specific #'s .5 and 5.5K
and yeah, i am hunting down a problem.
car not finding it's idol (any help would be great)
Hesitation
Threads Similar to: COP's
Coil Packs or COP's?? 68 dlxcoupe 4V / SVT 11 April 28th, 2008 09:11 PM
Accel COP's 1SLO85 Parts 1 January 26th, 2007 09:14 AM
