LinkBack (1) | Thread Tools |
#1
check engine light code with no defenition???
i got a p1100 and it says no definition avaliable. what the heck does this code mean? any help is greatly appreciated.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
1999 Mustang GT
TBD
Hope this helpsP1100 - Mass Air Flow (MAF) Sensor Intermittent The MAF sensor circuit is monitored by the PCM for sudden voltage (or air flow) input change through the comprehensive component monitor (CCM). If during the last 40 warm-up cycles in key ON engine running the PCM • Poor continuity through the MAF sensor connectors • Poor continuity through the MAF sensor harness • Intermittent open or short inside the MAF sensor. While accessing the MAF V PID on the scan tool, lightly tap on the MAF sensor or wiggle the MAF sensor connector and harness. If the MAF V PID suddenly changes below 0.23 volt or above 4.60 volts, an intermittent fault is indicated
Mushrooms...Mushrooms..In my head, Mushrooms...Mushrooms..In...mmyyy....Heaaad
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/69056-check-engine-light-code-no-defenition.html
| check engine light code with no defenition??? | This thread | Refback | May 2nd, 2008 09:04 AM | |
Threads Similar to: check engine light code with no defenition???
| Code p0340, sensor replaced, check engine light still off, but backfiring...help!! | tinkerbell_too | 99-04 | 55 | October 21st, 2011 10:40 AM |
| Engine Light Code | ricerraper33 | Audio/Video | 1 | December 27th, 2007 11:42 AM |
| 02 V6, Service Engine Light, Error Code P0445 | whtpny | V6 Mustangs | 25 | February 15th, 2007 10:27 PM |
| engine light code what is it ? | xxrals22xx | V6 Mustangs | 4 | January 24th, 2007 03:58 PM |
| CEL-Check engine light code P0340 | riscx | 2005 - 2010 | 0 | September 12th, 2006 06:52 PM |
