Discussing milage light in the 99-04 Forum. my odometer light has been blinking on and off kind of a minor annoiance untill ...
Old May 3rd, 2008, 12:13 AM   #1
sgrcltpunk's Avatar
1999 gt
stock
milage light
my odometer light has been blinking on and off kind of a minor annoiance untill today it decided to dim permanantly so you can hardly reed it so is thier a fix for this or what and how do you take it out
http://i84.photobucket.com/albums/k2.../hflvvvvvv.jpg
rep is appreciated
Old May 3rd, 2008, 12:16 AM   #2
Black02GT's Avatar
03 Mach 1--~--1 of 2513
8.9 1/8 mile time
wow that sucks. is everything else working okay in the speedo area? probably have to pull that thing out and change the bulb
probably have to take the dash trim off around it and should be 3-4 screws or something. and i think the plug is built onto the back so when you pull the assembly out it unplugs itself and when you put it back you just carefully push it back in snugly
Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice.
SaleenWolf720: need horsepower?? no, you just need bald tires, then you'll really feel the power
Old May 3rd, 2008, 02:45 PM   #3
sgrcltpunk's Avatar
1999 gt
stock
no see everything else is working just the odometer the rpm gauge works the speedo works and when i turn the lights on it lights up its just the mileage light but ill look and see if its just maybe the plug if anyone else has input id apreciate it
rep is appreciated
Old May 3rd, 2008, 03:32 PM   #4
RanGer498's Avatar
2001 Mustang GT
UNKown
i have the same problem in my expedition
Mods:
-PyPES cat back
-Ford racing springs
-Tires 275/17x9F & 285/18x10R
-S&B Cold air intake
-R498 10" Fixed Black mist Antenna
http://www.moddedmustangs.com/forums/signaturepics/sigpic14989_1.gif
©1969-2008
Old May 3rd, 2008, 05:52 PM   #5
MM's nicest mod, :)
White99stang's Avatar
its a cold solder joint in the readout. I can't remember what pin it is but thats what is causing the problem. I have the same thing in my expedition and i am a electronic technician who was training to solder crazy shit but i am just too lazy to go in there and fix it.
Have a Nice Day, Especially MSO
99 Mustang GT VT 302 Stroker 11.13@123 f.s. 9k
06 Dodge MegaCab Diesel 455rwhp/815rwtq
Old May 4th, 2008, 01:03 AM   #6
sgrcltpunk's Avatar
1999 gt
stock
so should i just replace the gauge cluster if so how much are they and where can i find some
rep is appreciated
Old May 4th, 2008, 09:41 AM   #7
sgrcltpunk's Avatar
1999 gt
stock
bump
rep is appreciated
Old May 4th, 2008, 11:42 AM   #8
RanGer498's Avatar
2001 Mustang GT
UNKown
but if you repalce the cluster how do you keep your milage with out going to the dealer ?
Mods:
-PyPES cat back
©1969-2008
Old May 4th, 2008, 11:54 AM   #9
MM's nicest mod, :)
it ain't cheap to replace the whole cluster, you might want to call a ford dealer and talk to them. By now i am sure they have seen the problem before. I would say remove the whole assembly and send it to me and i will resolder it for ya, unless you know how to solder, go buy some flux core solder wire and a soldering iron and just flow a little solder on each pin
Threads Similar to: milage light
milage? worth it? jaked588 99-04 24 October 25th, 2007 04:13 AM
What the highest milage 5.0 ever ??? Casper98GT The Clubhouse 16 October 11th, 2007 12:01 PM
Milage Help. Countryboy_99 94-95 7 April 1st, 2007 10:53 PM
milage patwrecked 5.0 Mustangs 9 March 29th, 2007 12:06 AM
Gas Milage acehogg69 2005+ 11 February 8th, 2007 02:06 AM
