2000 GT
I want to build a Turbo Kit
I basicly was looking into what I would need to start to put togather a turbo kit for my
2000 GT. I am on a budget that allows me to buy alittle at atime, so I just want to build up the kit from scratch. Only thing Im really having problems on is, WHAT turbo I should get, WHAT piping, and where the heck they sell the damn header for such a thing.. Thanks much |
Admanistrator
there is some guy who works at a junk yard that is getting tons of turbos and stuff he needs for free. ill try to get his thread for you
Admanistrator
cant find it. pm humsn
2000 GT
I saw that thred, and it went no where....
I started a new one hoping to bring up some new resources. Once again Im starting from scratch here, I need to know which turbo to get WHERE to get my header setup, and if it doesnt mount to the header, then a diagram of the piping layout to intercooler/exahust. IF ANYONE can help me on this would be much much much appricated. |
it all depends on the power levels you want, the flange your using. and what your goals are with the car. there are way t many option to just tell you which turbo to buy
2002 gt supercharged
ok ill try to help on the piping...
the right way it to have someone mandrel bend and cut your piping, Then bead the ends for a perfect fit, Then coat them with powder coating (cheap and you can do it yourself) Or keep it cool with polished ceramic like me and have a showroom finish
#7 | |
Admanistrator
2000 GT
I want to basicly put down about 375-400 hp.
I dont know where to get the header's though, and I dont know which turbo's to buy to start my kit. I dont care if it takes me a year to build it piece by piece, but I need to know where to start, I know alot more about HOW turbo's work now after reading some stuff on turbomustangs.com, but not really what KIND of turbo will work for a mustang specificly. Thanks again
2000 GT
btw I ment 375-400 WRHP
MM's nicest mod, :)
you will find much better info at turbomustangs.com. We can answer most of your basic questions here but if you need details of what all you need you need to go to that site.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Never Ran er!
+1 on The Turbo Forums.com some pretty impressive stuff and alot of how to stuff.
06 Mustang GT
I was strongly considering taking off my Saleen blower and going Turbo. I still might do it...
![]() Saleen Supercharger/Bassani Exhaust/Pro5.0/TeamJDM Supercharger Upgrade/440RWHP a million miles above sea level ![]() FOR SALE: Saleen Wheels/Tires and Black Bullitt Wheels. PM |
first off Turbo ftw...so your in the right direction
second i wouldnt use a junk yard turbo...not even rebuilt third i would go no less then a t4 flange for a turbo kit unless its twin then twin t3 flanges would be good also look at the power you want now and power you want in the future. a t4 is going to be plenty for a single kit, they have turbos that are small you could use like 57trims and as big as t80s for a single kit i'd say a .68 a/r or a .72 is good for a stock motor. for a built motor i'd go no less the .84 a/r with like a 72mm or t76 as for header piping 1 5/8 is a decent size or 1 3/4 would probably be a better idea 2.5inch piping of the headers or manifold to the turbo would be a good idea for a stock motor, 3inch is a bit excessive unless your looking for SERIOUS power like 800+rwhp maybe 700rwhp+ for the stock motor out of the turbos compressor 2.5 inch piping to the intercooler is a good choice then 3in out the exit side to your throttle body. and 3inch exhaust piping for a stock motor if you have plans on a built motor and 10s then 1 3/4 out the exhaust ports for the head 2.5inch or 2.75 to the turbo 3inch to the intercooler 3in or 3.5 inch to the intake. anything bigger or faster you probably shouldnt be asking then
[SIGPIC][/SIGPIC] Acmillr loves me Last edited by itschristorres8; May 5th, 2008 at 01:39 PM. |
2000 GT
I have noclue how to weld up a custom header....
how much would building a custom turbo setup cost??? like if i wanted small twins running 7lbs of boost?
http://www.cardomain.com/ride/3112249 |
#16 | |
the cost will be built upon turbo choice piping choice-if you go cheap...then it'll be cheap intercooler clamps fittings oil lines wastegate you choose blow off valve getting the flanges for it then you've got Mass air metter to upgrade fuel injectors and fuel pump a twin setup will be more expensive since buying the turbo is a big expense. btw if you choose crap parts you'll get crap a $500 ebay turbo you should NOT expect to last as long as a turbo from Garret buying the cheapest steel piping you can find may slowly bend over time with excessive heat, or rust. a cheap wastegate might spike at 10psi then result in 7psi at redline a cheap blow off valve will leak a cheap intercooler from ebay will not cool as well as precision or spearco cheap oil fittings may leak at 60+psi of oil pressure braided black fuel line IS NOT GOOD FOR OIL FEEDS to the turbo get the metal braided on the outside!
MM's nicest mod, :)
and if you don't know how to weld or fabricate your a little behind the power curve, i would rather spend 6k on a kit thats looks goods and works good than 1500 on a kit that looks like a blind person put it together and quality and longevity being unknown.
found 1 that is a single turbo kit for 3500 plus shipping and i need to upgrade the fuel system and get a new crossover. it was on that site white99stang put up earlier
#19 | |
+1 not to mention any leaks..
Threads Similar to: I want to build a Turbo Kit
| 3.8 V6 Turbo build overview | TurboLX | General Tech | 20 | November 15th, 2011 02:45 PM |
| Turbo Build - 01 Bullitt | BlckBullitt01 | 99-04 | 17 | June 16th, 2008 12:22 PM |
| 91 LX Motor And DIY Turbo Kit Build | wicked wendy | 5.0 Mustangs | 50 | November 19th, 2007 05:21 PM |
| Turbo HorsePower Twin Turbo kit | dblindberg | 2005 - 2010 | 34 | June 17th, 2007 09:05 PM |
| Turbo build question | acmillr | 99-04 | 11 | December 22nd, 2006 01:26 PM |
