Discussing To V10 or not to V10 "6.8L" 2004 Mustang GT in the 99-04 Forum. Originally Posted by Steele6599 I thought about it but wouldnt you need to run premium ...
Old May 6th, 2008, 01:20 PM   #21
DeMello's Avatar
01 nitrous injected GT
12s next time out...
Originally Posted by Steele6599 View Post
I thought about it but wouldnt you need to run premium gas as well? this build would only require regular...
no...there are plenty of kits (if not all) that you can run regular gas with...i plan on having a daily driver with more power then your tlking about and making the power with mainly boost. other people will need to inform you more about it but i know you can still fill up at gas stations
think bout this....terimes, gt 500s, lighitng, 427 roush, and similar fords come s/c and run on pump gas
NX wet kit, heater, purge, FPSS, window switch
PLX DM-5 wideband, raptor shiftlight, msd tach adapter
FRPP 410s, JLT CAI, STEEDA tri-ax, SCT x cal 3
STEEDA catback, SLP Loudmouths, UPR o/r X
NITTO Drag Radials, Zoom racing clutch
Old May 6th, 2008, 01:33 PM   #22
B0B
B0B's Avatar
2001 Mustang GT
the speed of smell
steele you are right v10 would be cool and unique.. it will end up costing you more money and you wont get as much out of it than if you built the 4.6 up.
here are some different ideas to consider:
you can either get a forged rotating assembly or a forged shortblock, both combinations you can go for the 5.0 liter stroker option if displacement is what you're looking for. a forged rotating assembly will cost you about $1600 whereas a forged shortblock will cost around $3200. the shortblock is pre-assembled and there won't be any work required you just have to bolt everything up (heads, intake, etc..) and drop her in. after you do the shortblock your engine will handle as much power as you can throw at it.
now there are several options you can consider for a power adder. if you want a cheap route you can put in a huge shot of nitrous, or you can go with a supercharger or turbo. i'm sure you've done your research on this stuff but a supercharger will run you from $2500 for a used setup all the way up to $6000, and that is a complete kit that will come with everything you need to get your car going. turbo kits are more expensive, but most of them come with a tubular k-member and coilover front suspension.
with this done you can EASILY have a 600+ rwhp street car, for about the same if not less than it would cost to do the v10 swap
'01 GT
P-1SC 383rwhp, 380rwtq
2003 Rubicon (DD)
05 Suzuki SV650S 55mpg
moddedmustang's drunk story teller
www.myspace.com/jeepwheelerbob
Old May 6th, 2008, 01:40 PM   #23
sgrcltpunk's Avatar
1999 gt
well if your worried about regular gas vs premium its on average 20 cent more per gallon so thats about $3.02 a tank but id get a v10 and sc it
http://i84.photobucket.com/albums/k2.../hflvvvvvv.jpg
rep is appreciated
Old May 6th, 2008, 01:42 PM   #24
Cool
Originally Posted by 06RedfireGT View Post
Keep in mind you will be adding a shit ton of weight to t he front end. It will handle like a bus. It would be much simpler and cheaper to forged and supercharge the current 4.6
I thought of that as well, that is why i included the approximate engine weight... things that I would do to compensate for the increase weight are the tublar A arms and K member and coilovers, fiber glass "Currently have Stalker" or carbon hood and relocation of the battery should more than make up for it... 140lbs is not that much... how much does Supercharger, Intercooler and all of its accessories way?
Old May 6th, 2008, 01:42 PM   #25
DeMello's Avatar
take bobs advice...and if you want you can first do the s/c and have about 400rwhp and then get the shortblock and raise your psi if you wnat to have 600+
and if this is gonna be a DD id suggest getting an intercooler
Old May 6th, 2008, 01:49 PM   #26
thanks, this is some good feed back, I actually did not think about moving the heads and etc.. to a new short block...
Im still looking at the cost as well...
Crate engine on ebay $3,000 with Harness and all "Could probably find cheaper in yard'
Kmember and A Arms plus coilover $700 GMS
GAS!!! would be Regular and not Premium, I dont think it would use any more than a supercharged 4.6 and maybe less.
Old May 6th, 2008, 01:55 PM   #27
B0B
B0B's Avatar
2001 Mustang GT
the speed of smell
a v10 will suck up a lot more gas man.. in normal driving conditions, superchargers and turbo's can actually increase your fuel mileage because they make your engine run more efficiently. Regency2007 used to have an 07 turbocharged GT with 4.10 gears and he reported getting 30+ mpg on the freeway.
'01 GT
2003 Rubicon (DD)
Old May 6th, 2008, 01:58 PM   #28
I beleive you maybe right... I definetly seen gas saving when a car was tuned with after market parts...
Dont you have to run Premium fuel?
Old May 6th, 2008, 01:59 PM   #29
DeMello's Avatar
if you plan on having a DD with that much power i wouldnt get a used engine from a junk yard or anyhting like that...im sure you can buy a brand new one with 0 miles on it that has some kind of warrenty
wtf u gonna do after buying a engine you think is a good deal and it blows up a couple days later?
Old May 6th, 2008, 02:06 PM   #30
B0B
B0B's Avatar
2001 Mustang GT
the speed of smell
well you could probably get it tuned to run regular but to be honest with you i dont see why spending .20 more on a gallon is such a big deal.. premium fuel is so much better for power, burns cleaner, and gives you better mileage
'01 GT
2003 Rubicon (DD)
Old May 6th, 2008, 02:13 PM   #31
Blown 03 GT
To get the most power with a s/c you do need to run premium pump gas, you can get it tuned for regular if you want, its up to u. As said before premium gas only adds like $3 to the bill, a 6.8L v10 will likely use more gas and end up cost more at the pump. The bigger the motor the more gas itll use.
Id say get a used s/c for under 3 grand and get it tuned for 400/400 or so wit premium pump gas. Then when that excitiment wears off get a forged shortblock and go crazy! Thats my plan for my 4.6.
PS, ull end up being lighter in the front than with the V10, especially after you get all the lightweight mods mentioned with the money u saved.
Old May 6th, 2008, 02:18 PM   #32
Thanks all for your replies, I would like to take this a different direction and lets say my only choice is the V10. Lets focus on the "gotchas"
6.8L V10 2V or 6.8L V10 3V "2005" or newer?
Cooling?
Weight Control?
Tunning what would you all reccomend?
Exhaust?
What over the counter products can I use?
What limitations, e.g. if I want to change the heads does the motor need to be pulled?
What are truck guys doing to increase power?
Thanks all you have been very helpfull...
Old May 6th, 2008, 02:21 PM   #33
DeMello's Avatar
you know for the money of getting your v10 in and installed youd be able to run like10s at the track by taking it the route of S/c and suspension
Old May 6th, 2008, 02:59 PM   #34
2004 GT
slow....
get a viper engine
2004 Crimson red GT
saleen s/c, full bolt ons
Old May 6th, 2008, 03:01 PM   #35
DeMello's Avatar
or keep it ford with a 5.4 all aluminum block straight out of an 08 ford gt
Old May 6th, 2008, 03:21 PM   #36
mr boogeyman's Avatar
2001 Mustang GT Auto
Wouldn't it be to much weight and make the car slower ?
Old May 6th, 2008, 03:26 PM   #37
DeMello's Avatar
wat hes tlking bout or me?
Old May 6th, 2008, 03:52 PM   #38
What he is talking about...It would give him more HP but seems with all the weight it won't make the car alot faster...But then again i don't know squat, just guessing. i would still do it for Hp though
Old May 6th, 2008, 03:53 PM   #39
DeMello's Avatar
i belive he posted that its 150 pounds heavier then the current one he has
Old May 6th, 2008, 10:50 PM   #40
beheivjer's Avatar
screw the nah sayers do to swap build the v10 and have fun.
1966 LUBR Bronco
1979 2.3t Cobra
1994 V6 Vert & a 351 ON A STAND
1997 Black Cobra
1994 Jeep XJ 4.5" lift 33"MTR
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Threads Similar to: To V10 or not to V10 "6.8L" 2004 Mustang GT
V10 bike?! ItaliStang The Clubhouse 8 March 2nd, 2008 01:32 AM
""ON EBAY 1 DAY LEFT 88 MUSTANG GT"" NYHigH For Sale 5 November 29th, 2007 07:38 PM
6.8L v10 lemon Engine 14 April 16th, 2007 01:22 AM
F-250 v10 Triton 06dkkiser All Other Vehicles 1 November 25th, 2006 03:11 AM
1/4th mile video of the v10 351 1999 prototype mustang SICK! flattusmaximus78 Multimedia 5 August 21st, 2006 06:01 AM
