LinkBack (27) | Thread Tools |
#81
Im glad there is some support now...
![]() Im currently looking for the 6.8L candidate... Very cheap at the Junk yards Also, did you all see the headers on Ebay? I definetly plan on going with the KMember for my swap to aid in the weight change... |
#82 |
I.D.G.A.F.
You're going to probably want ot have custom headers made, the truck headers more than likely won't fit. Custom headers uasully run about $1000+
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#83 |
2000 Mustang GT Conv
Stock
Waiting
Sorry about not delivering on the photos. The oil pan I sent out for modification has taken longer than expected and I still haven't gotten the parts I need to complete the 4.6 header modification. JBA has turned out to be pretty slow. I'll be having a talk with them later today.
Anyway, I don't know if I mentioned it before but I had to replace the brake booster and master cylinder with one out of a 96 gt so the pressure resivoir wasn't in the way of the Giant valve covers. I'll have to run new brake lines because of this but that won't be a big deal. The big deal is that fitting anything into the engine compartment behind the front four cylinders is nearly, no... not nearly, it's impossible unless you take the engine out to do it. Headers? Take the engine out. Brake booster? Take the engine out. Brake lines to the booster? Take the engine out. And forget about using the stock A/C lines, you can use the stock pump but the lines won't fit next to that, once again, Giant valve cover. I know now why ford hasn't made a Dual OverHead Cam version of the 6.8 V10. It wouldn't fit into ANYTHING. I'll keep plugging away though, I WILL make this work! |
#84 | |
Stock
Questions?If you have any questions about something specific and don't want to wait for me to post it here just email me at clarkebar@gmail.com, I check that every day. Try to get the engine from an F-350, it'll make EVERYTHING easier. Also, don't get rid of your old engine and all the parts attached untill you've completed the swap, there are alot of very useful parts on it. |
#86 |
Stock
Truck motor! In a Sportscar? |
#87 |
Pig Romancer
2003 GT
300.32@5.02mph
actually a lot of quick sports cars, and potentially quick sports cars use truck motors...the ka24 that's in 240 sx's is the same motor that's in Nissan trucks...it takes barely any tweaking at all to get that thing to run quicker than my gt...I know that because I've done it twice.
#88 |
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Hp Turbo Kit FTW
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#89 |
2008 GT500
Higher Octane (premium fuel) does not burn cleaner, or alter your mileage
Bob,
That just is not true. Higher Octane (premium fuel) does not burn cleaner, or alter your mileage. It does not directly give you more power, although it can allow you to run higher compression/boost that can result in more power. Octane rating - Wikipedia, the free encyclopedia The vast majority of automobiles on the road today are designed and manufactured to perform properly on regular grade gasoline. Premium grade (higher octane) fuel WILL NOT improve your mileage, or keep your valves cleaner, or give you noticeably better throttle response. The use of higher octane fuel in a vehicle that does not require it is simply a waste of your money. In an engine that does not "ping" on regular, the use of premium fuel garners zero benefit, period.
2008 Shelby GT500 ~ She's a Driver ~ Not a Garage Queen 2008 Bullitt #4602 ~ She's a Daily Driver ~ Not a Garage Queen http://good-times.webshots.com/album/562025025KJRMQW
#90 |
Pig Romancer
2003 GT
300.32@5.02mph
I was told by my auto body teacher back in high school that premium fuel would make your car get better mileage. I went and got a full tank of premium in my Cougar and ran that out, checking the miles I went. I then got a regular tank and checked the miles I went. I went right at 3 more miles on regular than on premium. Basically, it did nothing. I'm in agreement with Gt500 on the fuel thing based on my own results.
#91 |
Genibus Nitito Canus
its in the tune. if your going to use higher octane, u need to up the timing to see any improvement
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth ![]() |
#92 |
Pig Romancer
2003 GT
300.32@5.02mph
my car is supposed to be tuned for 93 (it acts like shit on mid grade and pings with regular)...but I'm pretty sure my timing wasn't advanced any...if I were to advance my timing how much would I need to advance it to make a difference?
#93 |
im not sure. i dont do much in the way of engine tuning, i just put them together and install them, its my dads job to tune them
#94 |
Stock
Progress
I got some more pictures. I had to take the engine back out of the car to put the oil pan/dip tube on. So while it's out I've bent the lines for the master cylinder/booster. There's a couple that don't fit but I'm getting adapters for those. I'm going to take care of the headers and exhaust before I put the engine back. It's gonna be a few days...
#95 |
that u and the v10?
#96 |
Windsor 2000 Mustang GT
I am watching this thread with much love for your enthusiasm to putting the v10 in the mustang, good luck sir...
CO |
#97 |
Stock
uh, huh. |
#98 |
2002 GT stock :(
mechanix glove
nice touch with installing a mechanix glove on the right cover! keep everything clean, nothing will slip, and lessen felt vibration!
#99 |
If you want to be just totally bad ass, i'd say just do the 3v 6.8l swap, and S/C it. i mean that would be totally sweet, and it'd would sound sweet as hell, my borthers 06 f150 with an x pipe and cherry bombs sounds bad ass and i know a guy with a S/C duals 6.8l and it sounds damn close to the same as my borther 5.4l, the 6.8l is basically a 5.4 with 2 extra cylinders. i would say just do all out that is if you got the money.
#100 |
That v10 in the mustang looks like the new 6.4l diesel in the f-350. Almost any repair is made cab-off. Anyway have u thought about wiring issues yet. I have yet to find much info on a standalone ecm's capable of 10 cylinder c.o.p. I have two v10's sitting in the garage i got as payment for rebuilding a 4r100 automatic awhile back and have long thought of a mustang swap. I figured on using the stock ecm with modded fuel injectors, fuel pump and ignition coils. They make direct replacement 80,000 volt coils (sniper tuning, aem performance). The pencil type coils do not use a spring to connect and the coil is integral to the stem which means less connections which in turn means less resistance and less problems. Also stock 6.8l with pi heads has a compression ration of 9.0 to 1. 52 cc combustion chambers and the same bore and stroke as a 5.4l. The v10 is odd firing and comes factory with a forged crank which is a blessing in disguise. The 6.8l is an odd firing engine which basically means more stress is put on the crank because of firing configurations which required the forged crankshaft. The good part is however the rods and pistons from the 5.4l are exactly the same. So if u want to increase compression ratios or lower them there are several
aftermarket options also change from hypereutectic to forged would be a good idea for FI. I have built several v10s they respond very well to porting and polishing. Even set up a few superduty's on N02. I can also attest to the tuning, in stock tuning form these engines are a dog, a programmer really wakes these up. In a mustang u could run the stock 6.8l ecm and just have someone flash you a custom program. Just make sure your network (twisted pair) communication wires are hooked back to your DLC. It will run right off the factory 6.8l truck pcm but do you really think you will get the potential of that engine when it is tuned for a 8000 lb truck where all that extra torque is required. Also BBK makes a bolt on throttle body for this motor. Comp cams has just come out with beehive springs and retainers this year and also has a custom grind camshaft available for these motors. Ford Triton V10 Cam Core (Left) 140-000-9L Ford Triton V10 Cam Core (Right) 140-000-9R Since it is essentially the same motor as the 5.4 with two extra cylinders just look at the grinds available for the 5.4l and choose one that suits your needs and they will grind it for you (quite a bit of $$$$ though). As for your oilpan you are right the best bet is custom making it yourself, in my experience alot of parts that should fit sometime don't. As for headers i have installed the stock jba headers in a superduty and clearance is about 1/4" to the frame so i have to say good luck and please post some pictures when u finish them. The v10 gets a pretty bad rap but I know u will be impressed when u get it running. I am a ford master mechanic and in 8 years at this dealer i have only seen two blow up. (both rod bearings one was in a rollover previously). Also any wiring issues or any questions you have feel free to ask. I also have access to all ford wiring diagrams and parts catalogues 1992- present. Good luck. Oh one more thing these engines like low gear ratios. I think 3.73 would be a great choice. |
Threads Similar to: To V10 or not to V10 "6.8L" 2004 Mustang GT
| V10 bike?! | ItaliStang | The Clubhouse | 8 | March 2nd, 2008 01:32 AM |
| 6.8L v10 | lemon | 5.0 Mustangs | 14 | April 16th, 2007 01:22 AM |
| F-250 v10 Triton | 06dkkiser | All Other Vehicles | 1 | November 25th, 2006 03:11 AM |
| 1/4th mile video of the v10 351 1999 prototype mustang SICK! | flattusmaximus78 | Multimedia | 5 | August 21st, 2006 06:01 AM |
