Discussing passenger window Squeak in the 99-04 Forum. Anyone else have a passenger window squeak during Cold weather. 50 degrees and below i ...
Old May 6th, 2008, 08:17 PM   #1
PowerShiftz02GT's Avatar
Anyone else have a passenger window squeak during Cold weather. 50 degrees and below i would say. Every time i roll up my window or down the window squeaks. The window rolls up fine and it seems like its on right. Is that little triangle rubber piece bad or something? any ideas?
5-Speed
BBK 70MM Throttle Body
Trick Flow Plenum
BBK CAI
Pulleys
Yokohama Performance tires
Flowtech Afterburner Mufflers
Mac O/R H Pipe
Old May 6th, 2008, 08:27 PM   #2
ZKid's Avatar
2002 GT
This is normal with our cars. Its the rubber all around the window, you can pick up some rubber silicone from an auto parts store, roll down your windown and spray the silicone on a rag. Then wiped down all felt and rubber around your window. Let it dry before you roll your window back up and your problem should be solved.
02 GT... JLT Cold Air/ Diablo Tune/ MAC Catback Exhaust/ FRPP 3.73's/ Steeda Triax/ Eibach Pro Kit... A work in progress.
Old May 7th, 2008, 07:11 PM   #3
alright thanks, ill have to try that
5-Speed
Trick Flow Plenum
BBK CAI
Pulleys
Mac O/R H Pipe
Old May 7th, 2008, 09:48 PM   #4
RC02GT's Avatar
yea mine sqeak real bad when there almost all the way up, gets annoying.
BBK CAI, BBK shortys, BBK x pipe, Flow's, MGW shifter
Old May 7th, 2008, 11:39 PM   #5
Hillsbaseball08's Avatar
8.15@86 (1/8)
Nice to know i'm not the only one.
07 GT500 & 2002 GT: 100 Shot Of Nitrous, 75mm BBK Throttle Body and Plenum, C&L Intake, Flowmaster Exaust, Bassani X Pipes, 3:73 Gear Ratio, BBK Upper and Lower Control Arms, Pro 5.0 Shifter, DiabloSport Tune, Underdrive Pulleys, Line Lock.
Threads Similar to: passenger window Squeak
Passenger window does not want to go down dgt_mustang V6 Mustangs 7 October 13th, 2007 03:03 PM
Re-Gluing The Passenger Window..... lwhitetrash88l General Tech 11 September 26th, 2007 12:19 PM
Passenger window leaking......help? lwhitetrash88l V6 Mustangs 14 August 8th, 2007 12:04 PM
Passenger window switch problem Plays With Squirrels Electronics 9 July 4th, 2007 08:46 PM
Squeak Squeak! DC97Cobra Suspension 4 November 26th, 2005 11:13 AM
