2011 Mustang GT
12.1 @ 116
Fuel Filter
So the other day my car stalled out while cruisin in 5th gear. I check the fuel filter and its the stock one and the car has 55k miles. Obviously 'dirty' fuel got to it and the fuel filter needs to be replaced.
I go and buy a Motorcraft one from Advanced Auto Parts and today after school I go to put it in, but I couldnt get the old one off... This was my procedure. 1. Press inertia switch and I let it sit for a few minutes to clear the lines 2. Go under the car and use a flat tip to take the bandclamp off. 3. I take off the C clamps on top of the lines that connect to the filter. 4. I went to pull the filter out of the female connecters and it wouldnt budge at all... Is there a specific tool I need to use to get the filter out of the female connectors?
Mods in garage. Built suspension and gears since posted times. |
yeah its a fuel line disconnect tool. it's like 8 bux at autozone. its a 5/16's i do believe.
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
2011 Mustang GT
12.1 @ 116
thanks bro. I knew it couldnt be THAT hard to get something so simple out.
+rep
yeah, the teeth on the inside are like reverse. you gotta jam that thing in there and it releases. it's hard to explain the design. but basically its like a quick release that isn't quick. lol
2011 Mustang GT
12.1 @ 116
i know what your saying. its gotta lip on the filter and that slips over the top
yeah, there are little teeth that hold it. that's why you need the special tool. you got the idea.
yeah, its like 6 bucks at advance and yes its a 5/16
2003 GT Vert
hahaha lol
I did the same thing. The haynes manual didn't say anything about the fuel line tool and I pulled and pulled for like 30 minutes. Then I stopped pulling, started yelling and cursing, and then I pulled some more. Finally gave up and searched MM and found the answer. Felt like such an idiot...
03 GT mods: Bassani o/r x-pipe, Magnaflow catback, MGW shifter, FRPP 3.73's, JLT RAI, Xcal 2 tuned by Trick Tuners, FRPP Aluminum DS, grill delete , chin spoiler, shorty antenna Next Up : Stewart Water Pump + Steeda UDPs |
#9 | |
2011 Mustang GT
12.1 @ 116
yeha i knew it couldnt be THAT hard. oh well. Ill pick it up tomorrow and do it tomorrow night...
so where is the enertia switch located?
BULLITT CREW #5 LT GTB mufflers for sale
48.47@ 12.58
in the trunk drivers side behind the tail light carpet.
awesome...thanks ...im doing filter and spark plugs this weekend...any recomendations on spark plugs?
48.47@ 12.58
ngk or auto light. make sure they are copper.
autolite extremes any good? or bosch irridium?
48.47@ 12.58
just get the copper plugs man..
also im buying tools as i go along...do i need spark plug sockets? i have a basic socket set and screw drivers so far..
48.47@ 12.58
yes.. and get a few extentions as well
so if the original plugs were platinum...why copper?
48.47@ 12.58
copper is a better conductor and platinum when exposed to high amounts of hear melts.
platmiuns only upside it that they last longer.
Just a bit of advice, don't smoke while changing out the filter, and don't light the old filter on fire once its out...... it.... does stuff. =(
Threads Similar to: Fuel Filter
| fuel filter | 01dutchGT | 99-04 | 4 | February 9th, 2008 11:33 PM |
| 99-04 fuel filter help!?!?!? | motorhead6776 | V6 Mustangs | 7 | February 2nd, 2008 06:47 PM |
| Lucas fuel injector cleaner and fuel filter | Saleen0101 | Modular Mustangs | 0 | September 25th, 2007 03:09 PM |
| fuel filter | JASonic | V6 Mustangs | 2 | February 25th, 2007 11:30 AM |
| Fuel Filter 96 GT | Beatz | 96-98 | 1 | September 12th, 2006 05:06 PM |
