Lincoln Mark 7 8.8 Rear
Old October 27th, 2006, 05:03 PM   #1
88LSC is on a distinguished road
Does anyone know if the Mark 7(87+) rear end is the same width as the 99+ Mustang's which is 1.4 inch wider then the 79-98 rear.As it would be a cheap up grade for the 7.5 rear guys.
Old October 28th, 2006, 01:06 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
- 1994-1998 Mustang rear axles are 3/4" wider on each side than a 79-93 Mustang.
- 1999 and newer Mustang rear axles are about 1 7/16" wider on each side than a 79-93 Mustang
- Lincoln Mark7 LSC, SVO Mustang and Fox Body Saleens use a rear axle that is 1.25" wider per side than the 87-93 Mustangs.
Old October 28th, 2006, 03:54 PM   #3
so all the housings are the same width?just longer axles right?
Old October 29th, 2006, 10:19 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The housings are different widths too.
Old October 30th, 2006, 12:21 PM   #5
so agian does anyone know if the mark 7 and the 99-04 Mustangs have the same width rear ends.
Old October 30th, 2006, 03:18 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Like I said, "Lincoln Mark7 LSC, SVO Mustang and Fox Body Saleens use a rear axle that is 1.25" wider per side than the 87-93 Mustangs" and "1999 and newer Mustang rear axles are about 1 7/16" wider on each side than a 79-93 Mustang" so with that being said the Lincoln Mark VII rear end is about 3/16" narrower on each side than a 99+ Mustang.
Threads Similar to: Lincoln Mark 7 8.8 Rear
Difference between 98 cobra and Lincoln Mark VIII mod motor? noyz25 Modular Mustangs 35 October 18th, 2007 07:42 PM
mark 8 flattusmaximus78 All Other Vehicles 3 June 30th, 2007 10:51 PM
Shelby GT Mark-up? oldernewbie 2005 - 2010 11 May 7th, 2007 01:51 PM
5 lug/ Lincoln rear end question dblack 5.0 Mustangs 2 January 3rd, 2007 08:28 PM
