Stock Driveshaft with Cobra Diff and 31 splines?
Old May 12th, 2008, 09:43 AM   #1
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
Alright so here is my question.
I already ordered my gears and install kit, now i am onto differential and axles. I dont want to break an axle at the track. i'm running nitto 555r's. If i get the 4:10's put in, how likely is the possibility of them breaking?
Also, is the 31 spline driveshaft from FRPP compatible with the cobra differential. I have done as much searching as i could but can't find anything. Thanks for the help guys
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old May 12th, 2008, 11:00 AM   #2
SteviGX's Avatar
Anyone?
Old May 12th, 2008, 11:01 AM   #3
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
31 spline drive shaft??
the cobra diff will work with your stock driveshaft.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old May 12th, 2008, 11:04 AM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ +1
Old May 12th, 2008, 11:06 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
drive shaft mounts to a flange, all 8.8 gear sets are the same tooth pinion. the stock axles will hold a lot, i was on stock axles for a long time. i launch at 5500 N/A, and 3400-3800 on the juice with et streets and stock rear end set up. i now have a little stronger set up, but my stocker held up just fine.
Old May 12th, 2008, 11:10 AM   #6
SteviGX's Avatar
alright. thanks guys.
I meant to say 31 spline yoke. I wasn't sure if that would work with the cobra. But thanks guys.
Old May 12th, 2008, 04:09 PM   #7
97 Cobra
97SnakeBite is on a distinguished road
Send a message via AIM to 97SnakeBite
the OEM on stangs is 28 spline axle shaft w/28 spline Diff..in oother words if u get 31 spline aything u need to upgrade all to 31...
Norcal SVTOA Sacramento Persident/Director
http://i19.photobucket.com/albums/b197/famouskid34/97SnakeBite.jpg
Old May 12th, 2008, 04:10 PM   #8
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
it's a 31 spline yolk in his year and a 28 splice diff..
the drive shaft itself is a direct bolt on.
Old May 12th, 2008, 04:27 PM   #9
97 Cobra
i was thinkin axle shafts for some reason..but u r correct on the yolk
Threads Similar to: Stock Driveshaft with Cobra Diff and 31 splines?
vibration with stock driveshaft? mustang fanatic 2005 - 2010 5 May 3rd, 2008 08:44 PM
Aluminum Driveshaft -- splines.. whtpny 99-04 16 February 28th, 2008 03:12 PM
Driveshaft ( 01 Cobra) Montanasvt 4V / SVT 15 February 2nd, 2008 10:13 PM
Is mustang 2005 GT stock limited slip diff or not? Evilspark 2005 - 2010 1 September 10th, 2007 02:34 PM
diff in 94 cobra and 96 gt trebel14 Modular Mustangs 6 February 19th, 2007 08:59 AM
