Discussing short throw hangin up? in the 99-04 Forum. so i just bought this '02 GT and it came with a short throw shifter, ...
Old May 12th, 2008, 08:05 PM   #1
FoxHoss's Avatar
02' GT
Question
so i just bought this '02 GT and it came with a short throw shifter, no idea what kind, but its orange. when the car is not rolling, aka at a stoplight or what not it can shift through the gears no problem, however, when im cruisin and i go to bang out some gears it seems to get hung up for a sec between shifts. i thought i was being sloppy so i made sure i was hittin the gears dead on but it still will get hung up momentarily and drop into the gear, any ideas? on the brand of shifter or the problem
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
'02 GT ~ dd
'89 LX ~ still in swap mode
'78 F-250 ~ swaped 429ci out of '69 mustang
Old May 12th, 2008, 08:23 PM   #2
Doc8224's Avatar
2003 Mach 1
Its an MGW shifter
Take it out and see if its gummed up. Clean it out
Under Construction
Project N/A 4V Under Way
Rep is always welcome
Old May 12th, 2008, 08:49 PM   #3
sounds like the problem i have and its probably a bent shift fork
Old May 12th, 2008, 08:55 PM   #4
Rico-mofos's Avatar
2004 mustang GT
r u sure you dont mean it kinda clicks into each gear?
You have to work up to it slowly.
After a few months of thumbing/fingering/rubber booting her anus, you're ready to ask her if you can attempt anal.
Old May 12th, 2008, 08:57 PM   #5
disreguard my post i didnt read carefully mine doesn't go in at high rpm. i thought yours was the same.
Old May 12th, 2008, 09:21 PM   #6
2004 mustang GT
12.7@111
I have an 04 and the tail shaft seal went. The dealer put the wrong fluid in it and it would not go in at high rpms. I made them change the fluid again and it's perfect.
Old May 12th, 2008, 09:22 PM   #7
FoxHoss's Avatar
02' GT
while driving whenever i shift as the shifter lands in the "neutral area" it comes to a dead stop for a fraction of a second then pops into the gear i want... is there a mechanism that needs to be adjusted? it makes fast shifts practicly impossible, yet when im not rolling it shifts perfectly fine
btw thanks for the heads up on what kind it is
'02 GT ~ dd
Old May 12th, 2008, 09:43 PM   #8
Doc8224's Avatar
2003 Mach 1
Synchros or shift fork. there is only a shaft and centering springs in the shifter, no mechanisms. Most likely its in the tranny. You can drain the tranny and refill it with some good new tranny fluid and see if that helps.
Under Construction
Old May 12th, 2008, 09:43 PM   #9
2004 mustang GT
12.7@111
is it just at higher rpms
Old May 12th, 2008, 09:46 PM   #10
FoxHoss's Avatar
02' GT
its at any rpm, its only got 17k miles on it i hope the tranny isnt fucked up... tommarrow ill change teh fluid and hopfully that will help
'02 GT ~ dd
Old May 12th, 2008, 09:49 PM   #11
Doc8224's Avatar
2003 Mach 1
The reason I say synchros is because it doesn't do it when you are sitting there, shift fork will do it even when you are going or sitting most of the time.
Under Construction
Old May 12th, 2008, 09:57 PM   #12
futureMACH1racer's Avatar
2004 Mach 1
Too Slow
+1 on the synchros
Hey bro, you been doing any powershifting, slamming it into gear at all? If not the previous owner probably did. The T-3650 are great tranies, but they don't hold up to powershifting for very long. I suggest start out with the process of elimination. Clean the shifter, flush the fluid, then go to a tranny shop. The dealer is going to be twice as high, and only give you what you had before. I suggest beefing it up if you have to go inside and repair it.
MM MACH 1 CREW MEMBER #2
REP IS APPRECIATED
2008 Yamaha FX Nitro RTX for sale 0 miles still in plastic $11,000 firm
Old May 12th, 2008, 10:00 PM   #13
FoxHoss's Avatar
02' GT
oh god... here comes the checkbook haha
'02 GT ~ dd
Old May 12th, 2008, 11:01 PM   #14
the real shocker's Avatar
13.00 @ 105
when my synchros first started showing signs of wear in my 3650, i drained the fluid and put 2 liter's of ATF in it and 1 of synchromesh, and it got better for several more months.... but alas, it comes back
good news though, if you are competant enough to pull the trans and know someone that will fix it for you on the low, you can get a nice set of synchros for a couple hundred bucks.....granted nothing else needs replacing
02 GT - SOLD
Old May 12th, 2008, 11:33 PM   #15
FoxHoss's Avatar
02' GT
what kind of specialty tools do you need to overhaul the 3650? ive rebuit auto's before no problem. if the tools arent to bad then i might be feelin squirley and try it on my own
'02 GT ~ dd
Old May 13th, 2008, 01:37 AM   #16
97 Cobra
shifter need adjusting....check your fluid make sure its good
Norcal SVTOA Sacramento Persident/Director
http://i19.photobucket.com/albums/b197/famouskid34/97SnakeBite.jpg
Old May 13th, 2008, 09:14 AM   #17
2002 mustang gt
13.50@102
my pro 5.0 does the same thing for third gear but only when it is in high rpm's, it either doesnt go into gear or it does but makes a grinding noise. any advice
Old May 13th, 2008, 04:34 PM   #18
FoxHoss's Avatar
02' GT
mine dosent grind, im hoping some ass put gear oil in it and thats all but i may be fucked and have to pull out the wallet
btw what type of fluid is best for my tranny???
'02 GT ~ dd
Old May 13th, 2008, 04:55 PM   #19
2004 Mach 1
Too Slow
My MGW works great. I love it, it's a whole lot better than my old Tri- Ax.
REP IS APPRECIATED
Old May 13th, 2008, 09:59 PM   #20
Doc8224's Avatar
2003 Mach 1
Royal Purple synchromax.
Under Construction
Threads Similar to: short throw hangin up?
Best short throw? silverstang 2005+ 37 April 15th, 2008 10:26 PM
Short throw. Elder 4V / SVT 8 March 1st, 2008 09:41 AM
Short throw AnglicoGT98 99-04 9 January 16th, 2008 11:43 AM
Used short throw smoke-em 99-04 6 October 10th, 2007 08:11 PM
Short Throw.... THE HOFF 99-04 13 February 15th, 2007 02:00 PM
