![]() iTrader: 1 reviews
Mach 1 and Cobra
Do these two have the same engine aside from the supercharger, or are they two different engines?
RLY SRS
What year Cobra are you talking about?
I am guessing the 03/04 cobra... Mach 1 Engine Layout: Front Engine, Rear-wheel drive Engine Type: MOD 4.6L DOHC V-8 Aluminum Block Displacement: 4.6L, 281 cu. in. Horsepower @ rpm: 305 @ 6000 Torque lb-ft. @ rpm: 320 @ 4250 Compression Ratio: 10.1:1 Bore and Stroke: 90.2 mm x 90 mm (3.55 in. x 3.54 in.) 99-01 Cobra Engine Layout: Front Engine, Rear-wheel drive Engine Type: MOD 4.6L DOHC V-8 Aluminum Block Displacement: 4.6L, 281 cu. in. Horsepower @ rpm: 320 hp @ 6,000 rpm Torque lb-ft. @ rpm: 317 lb.-ft. @ 4,750 rpm Compression Ratio: 9.85:1 Bore and Stroke: 90.2 mm x 90 mm (3.55 in. x 3.54 in.) 03/04 Cobra Engine Layout: Front Engine, Rear-wheel drive Engine Type: MOD 4.6L DOHC V-8 Iron Block Displacement: 4.6L, 281 cu. in. Horsepower @ rpm: 390 @ 6000 RPM Torque lb-ft. @ rpm: 390 @ 3500 RPM Compression Ratio: 8.5:1 Bore and Stroke: 90.2 mm x 90 mm (3.55 in. x 3.54 in.) I made a chart that has all the details on it...Its in excel I will add it as an attachment...Well I cant upload spread sheet attachments...So if you want it post your email and I will send it to ya... |
unstoppable @ speed of light
Well I don't have a chart like ChrisJ, but I do know that the Mach's have higher compression ratio's than the cobra's, also I think the 03/04 cobra's have all forged internals, because of the supercharger. But Mach 1's are still the best in my biased opinion!
same design but they do not have the same internals. the machs have forged cranks but the rods and pistons arent forged
#5 | |
RLY SRS
I amde the chart becuase I was bored and wondered the same thing... |
the 03/04 cobras have a forged block as the earlier cobra bolocks were alluminium
so for them being the same minus the blower, no they are not the same.
so would SHM have an engine that is the same as the cobra engine? or am i just not seeing it?
The same in which aspect? I don't know if they would carry a completely origional cobra engine, it would be most likely upgraded in some way.
i was talking pretty much the cobra engine minus the supercharger
They probably have something pretty comprable. Most likely better.
#12 | |
2002 GT K&N CAI O/R X-Pipe Race Bullit Mufflers SCT Xcal2 w/Custom Tune By RWTD 4.10 Rear Nitto D/R's FR500 Rims 17x9 17x10.5
*buddies*
RLY SRS
You can run boost on the aluminum block...They disapate heat laot faster...They both have their good points and bad points...
Threads Similar to: Mach 1 and Cobra
| 99/01 Cobra Or 03/04 Mach 1 | 00GT | 99-04 | 88 | April 16th, 2010 10:56 AM |
| Mach 1 Instead Of Cobra | B0B | 99-04 | 39 | November 16th, 2007 02:31 PM |
| 99/01 Cobra or 03/04 Mach 1 | 00GT | 99-04 | 1 | May 16th, 2007 05:00 PM |
| Cobra or Mach? | mustangstud13 | 99-04 | 43 | November 24th, 2006 07:54 PM |
