2011 Mustang GT
12.1 @ 116
IAC
Would a dirty IAC cause the rpms to hang a little between shifting and when coming to a stop?
When IM coming to a stop, its becoming more and more often that the rpms hang at 1000 then drop to 800 when I finally come to a complete stop. Is the IAC the culprit?
Mods in garage. New mods, new track times soon. |
MM's nicest mod, :)
yep, ford iac, the biggest piece of shit they ever made.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
2011 Mustang GT
12.1 @ 116
I dunno what happened, it posted twice...
sorry you can delte this one white
2011 Mustang GT
12.1 @ 116
![]() I think their headunits are a close second... So what can I do? how exactly do I clean the bugger?
MM's nicest mod, :)
i have never cleaned them, i just have replaced it on my car 4 times already. But if you do a search i know for a fact its posted on how to take it apart and clean it
2011 Mustang GT
12.1 @ 116
thanks for the help dude. could you delete that one post above for meh? sorry bout that
2003 Mustang GT
also another thing you can do would be to make a new gasket for the IAC that is thicker, did it to mine and its much better now
2003 GT Dubbed project "Black Mamba" Stage 1 Complete. Stage 2 Commencing. |
Boost gets you laid
i made an IAC restrictor plate and it took care of the hanging idle. makes it funner to drive and can actually increase your mileage a little bit too.. idle is louder though
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
1999 Mustang GT
13.8
How ya go about doing that? and what do ya mean by restrictor palte, block some thing off for it or something? I havent looked at mine yet, but have that idle problem,and when I bout my 99 a few weeks ago it already had a new iac installed, so looking for any ideas I can here, any detailed info would be great
99 forrest green vert: -Diablosport Predator & Tune (removed for cheap gas use) -Motive 3.90 gears -MRT Catted H -Flowmaster American Thunder catback -Eibach Sportlines -Tokico D-Spec shocks & struts My Garage |
Boost gets you laid
i made my restrictor plate using a piece of aluminum, but you can buy them off ebay here. what it does is makes the hole much smaller so not as much air can pass through. it makes rpms drop way faster and also makes the car gurgle a little bit when you let off the gas. the reason the IAC doesn't shut when you let your foot off the gas is for emissions reasons. ford designed it to stay open, letting more air in to burn up the excess fuel when decelerating. they are easy to make, just use your gasket as a template and cut out a piece of metal. i used a 9/32 drill bit for the hole on mine
1999 Mustang GT
13.8
cool, thanx for the info, Im gunna have to try that then, I am sick of keeping aroun 1k rpm till I completely stop, now I just have to figure why it wants to die then shoot upto 3k rpm after I stop (new iac). But at least I am getting off to a decenet start here, you guys at these boards really have good advice and knowlege. I'd know a bit more but this is my first 5 speed gt, so before when id look stuff up most 5 speed posts in boards never really apllied to me, been more of an auto guy
99 forrest green vert: -Diablosport Predator & Tune (removed for cheap gas use) -Motive 3.90 gears -MRT Catted H -Flowmaster American Thunder catback -Eibach Sportlines -Tokico D-Spec shocks & struts My Garage Last edited by M0T0PSYC0; May 14th, 2008 at 03:50 AM. |
1999 Mustang GT
13.8
ok another question on the restrictor plate. wich hole gets normal size and wich small. Comparing as one hole shows the valving and other just shows the aluminum casing. small hole for the aluminum casing hole and valving hole normal size? or other way around?
When you decelerate the rpms are supposed to hang up to 1500rpm to allow accessories like power steering to work.
Vortech V2 Si
Yup,
The PCM, using the IAC, keeps the idle high until you actually stop to make sure the power brakes have sufficient stopping power. An IAC restrictor won't change this much, unless you make the hole so small the idle as a whole is affected. I played with gasket's and playes but it was a PITA to test different size holes, so I made a plug for the IAC inlet hose. 0.290" (19/64" drill) or so seems to work best. ![]() People have use a 1/2" copper pipe cap as well...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
2011 Mustang GT
12.1 @ 116
so the rpms hanging for a little bit is biggie then?
thats how it should be when you decelerate
Vortech V2 Si
It's normal for our cars, however it's also one of the first things I modified because it irritated the crap out of me. With the 0.290" orifice I now have the reves drop smartly while shifting and there's a bit of a "pop and burble" almost like a carbureted engine would do...
2011 Mustang GT
12.1 @ 116
mine still does that pop and gurgle when I leave it in gear and the engine slows it self down. i love that sound.
I was talking about the entire rpms hanging at 1000 rpm then droping when you completely stop.
That is, as I said earlier, an artifact of the hydroboost braking system which uses hydraulic fluid pressure from the power steering system to provide power-assisted braking. The engine speed is deliberately held high while the vehicle is moving to ensure adequate braking capacity.
Threads Similar to: IAC
| IAC | scxc15 | V6 Mustangs | 7 | November 24th, 2007 07:39 AM |
| IAC | scxc15 | General Tech | 0 | November 22nd, 2007 10:06 PM |
| IAC | AnglicoGT98 | General Tech | 2 | September 21st, 2007 06:43 PM |
| iac | punkafi888 | V6 Mustangs | 10 | April 29th, 2007 11:52 PM |
| IAC | 98StangGT | 96-98 | 5 | September 28th, 2006 04:54 PM |
