Discussing problems starting sometimes in the 99-04 Forum. i was just wandering if this is happening to any one else its an 03 ...
Old May 15th, 2008, 12:09 AM   #1
03 gt 95 gt 92 lx
na
Unhappy
i was just wandering if this is happening to any one else its an 03 gt some times when i turn the key it crans over for a few seconds before it fires up and it sounds like its not getting fuel if i release the key before it fires up then try to start it right away it takes even longer to light off i did a full tune up fuel filter and it only does it once in a while when its hot there are no codes it runs great just every 10 or so days it does that i some one said i might have a vapor lock has any one ever heard of that but none of my other mustangs ever did that
Old May 15th, 2008, 12:15 AM   #2
Try holding your foot on the gas next time and see if it starts it it does it could be you IAC. But if you crank it over and you let off the key too soon it could cause it to crank longer its a value strategy in the pcm, Ford says to crank in upwards of 8 secs or so before it could start
Old May 15th, 2008, 12:16 AM   #3
zinc02GT's Avatar
Slow
spark plugs maybe? whens the last time you did that?
could be spark plugs, IAC, or MAF. thos would be my guesses
The only way to learn about a car truely is to break something and fix it yourself...
Originally Posted by graystang01 View Post
cams demello'd a viper
nuff said
Old May 15th, 2008, 12:20 AM   #4
injected03stang's Avatar
2003 MUSTANG GT
11.86 @ 114.21
^^^ i agree probbaly the iac.... that will throw a code for gas lid or vapor lock
Originally Posted by jdansby1 View Post
Street racing kills-Go kill yourself!
BLUE MUSTANG OWNERS CLUB
FOUNDER MEMBER # 1
REtarD HATERS CLUB
CO-FOUNDER MEMBER #2
(Blue Branch Founder)
Old May 15th, 2008, 12:05 PM   #5
mbmconstruction00's Avatar
2004 GT
my car has done it since day one...i know a few others that do it too...
Vortech Mongoose Kit,Mac LT's & Pro-Chamber,SLP LM2,3:73,Accufab T-Body & Plenum,Pro 5.0 Shifter,FR500 Deep Dish Rims,H&R Springs,KYB Adj,MM CC Plates,Mach 1 Grill Delete & Spoiler,HID's,Saleen Wing,Steeda X2 & Bumpsteer
Old May 15th, 2008, 12:25 PM   #6
the real shocker's Avatar
13.00 @ 105
if you jump in and turn the key without giving the fuel pump time to prime, that happens
Old May 15th, 2008, 01:18 PM   #7
Shibby50's Avatar
ive had the same problem, once every few days after i shut the car off when its hot, if i dont wait more than like 15 min. it just cranks for a long time n i have to sit for a few before it starts...
2000 GT Convertible
Lowered 1.8in. Procharger P1SC 8lbs, Bassani X-Pipe, Flowmaster Mufflers, 42lb injectors, full sub-frame connectors and x-brace
Winter mod list: Gears, stall, 3.2 pulley, 75mm tb & plenum, wideband, headers & ory
Old May 15th, 2008, 01:59 PM   #8
cliffyk's Avatar
My '03 GT has done this since I have owned it (I got it at 30k miles, 73k now). When it's hot and has been sropped for just a short time--like running into the store for a 6-pack.
All cars have certain quirks, and in the 1-1/2 years I've had the car it has done this maybe a dozen times; waiting just a couple seconds between key ON and Start does seem to minimise the problem.
-cliff knight-
My Mustang GT
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 252 rwHP/296 ft.lb.
Multi-fuel: burns gas and rubber...
Old May 15th, 2008, 04:34 PM   #9
2002 Ford Mustang GT
I HAD the same problem with my 02GT. When hot, (the car that is), it would fail to start prob every other time. Cranking it a second time, always got it going. Since I had it worked on a year ago, it hasnt done it once.
I had the following service recommended to me:
BG Findashop - Fuel/Air Induction Service
In hindsight, I would have tried seafoaming the crap out of the car first, as this service cost me like $140. However I cant argue with the results. it fixed it, pure and simple. Dont know if seafoam would work as well, but I would have tried it first if I had known about it back then.
Here is what the mechanic told me. When carbon builds up inside the engine, it acts like a sponge for fuel. When you shut the car off, the gas seeps out of the carbon and into the cylinders causing a flooding condition upon hot restart. If you give the car enough time to cool down, you also give the gas enough time to exit the cylinders by itself,therefore avoiding the flooding condition.
Call bullsh1t if you want, but it fixed my car perfectly, and I couldnt be happier.
Old May 15th, 2008, 04:38 PM   #10
luis's Avatar
2001 GT
could also be the starter..
2001 Mustang GT
*Starigth 3" piping exhaust
*Steeda Lowering springs
*Mach 1 Chin spoiler
*Ram Air kit
*Functional Scoop
Old May 15th, 2008, 09:00 PM   #11
Bullitt2445's Avatar
2001 Bullitt #02445
The problem you are discribing is Vapor Lock. Since the injectors are firing and the spark plugs sparking, the computer will not put out a code for the problem. Some (maybe most) of the 2001 Bullitts are affected by this problem because of the aluminum intake and the heat they retain, especially on quick stops. To prevent the problem, turn the key on, buckle your seat belt, then start. Should fire every time.
2001 Bullit #02445 built in the only color Henry would build- Black.
Old May 16th, 2008, 12:56 AM   #12
03 gt 95 gt 92 lx
na
thanks for the info guys that was a big help now i just got to get the carbon out lol
Threads Similar to: problems starting sometimes
Cold Starting Problems (Again) Top Gear V6 Mustangs 10 November 19th, 2007 10:21 PM
Starting Problems MustangDrew212 Modular Mustangs 1 August 18th, 2007 01:46 PM
Starting Problems 82DragMan 5.0 Mustangs 5 April 29th, 2007 06:46 PM
Starting problems Mudv216 5.0 Mustangs 5 April 16th, 2007 01:03 AM
Problems Starting Donbeil 96-98 0 January 11th, 2007 09:12 PM
