Discussing pinion leak? in the 99-04 Forum. I just had gears put in about 3 months ago and i recently smelled gear ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2004 mustang GT
pinion leak? |
2004 mustang GT
i bump thee
2004 mustang GT
bump
on my penis |
13.00 @ 105
its an easy fix....
-disconnect four driveshaft bolts, move driveshaft out of the way... -unscrew the pinion nut (this is where its ideal to have an impact gun and a "larger" socket collection.. i *think* its a 24mm socket, but its been a while and i'm not certain) -pry old pinion seal out -clean up around the area, make sure there are not burrs or anything that could rip the new seal -silicone around the area and reinstalled the new seal, be careful putting it in, do it evenly -put pinion nut back on -silicone around everything again -reattach driveshaft and take off
13.00 @ 105
and check/refill rearend fluid level afterwards, you will lose some with this process
2001 Bullitt #02445
If you are not careful, when you reinstall the pinion nut, you can crush the pinion bearing. If it were me, I would take it back to the shop that did the gears and have them check thier work.
2001 Bullit #02445 built in the only color Henry would build- Black.
Threads Similar to: pinion leak?
| Ring and Pinion Q? | eLLuSioNiST | 2005+ | 17 | May 11th, 2008 08:53 PM |
| Ring and Pinion Help | andres0286 | 99-04 | 4 | March 24th, 2008 03:24 PM |
| pinion snubbers | fsttang96 | 96-98 | 0 | October 25th, 2007 06:59 PM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 04:46 PM |
| rack and pinion | hmotes | 5.0 Mustangs | 2 | December 2nd, 2006 10:59 PM |
