Help: 99 GT leaning
Old May 15th, 2008, 02:58 PM   #1
MustangPilot is on a distinguished road
Help: 99 GT leaning
Hello everyone,
Newly registered member and glad to be here.
I own a 1999 Mustang GT Convertible with 15.5k miles on it. I am the second owner of the car and it has an aftermarket suspension consisting of Bilstein shocks and Eibach lowering springs. I have owned the car since 2003.
I have noticed in the last year that the car leans to the drivers side. The car seems to ride fine, but only until recently has it really started bugging me when I look at it. The left side looks perfect, but the right side is about .4" higher when measured. I was just wondering if anyone could help me understand why it could be leaning? I have attached a photo of the rear just to give an idea of what it looks like. I should also add that I am 165lbs.
Any help would be greatly appreciated!
- Lawrence
Help: 99 GT leaning-100_0011a.jpg
Old November 10th, 2008, 04:12 PM   #2
99 GT
klean4.6 is on a distinguished road
My fox did this from torque, twisted the frame. You need to invest in some sub frame connectors from Maximum Motorsports.
Old November 10th, 2008, 08:44 PM   #3
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
If you twisted the frame due to torque, you are running some SERIOUS HP in your fox. Truth is the Fox body does not have great support frame-wise, so frame connectors are a good idea anyway. The SN95/New Edge is about 25% stiffer than Fox and the S197 about 75% more than SN95/New Edge. I have upper/lower SF support in my ride and think it is good idea as VERY important for good handling ride and lessens issues of rattles and poor fitting doors and such.
I would get the car up on a rack and do some close inspection. You could have a sagging spring, but more likely a deteriorated spring pad(s).
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old November 10th, 2008, 08:47 PM   #4
MM.s Used Car Whore
svtkidd23's Avatar
2011 F150 XLT 4x4 5.0
14.89
svtkidd23 is just really nicesvtkidd23 is just really nicesvtkidd23 is just really nicesvtkidd23 is just really nicesvtkidd23 is just really nice
mine does it to.. but opposite..
not as bad though
Originally Posted by Thumbie View Post
I don't have a condom" She was like "oh I'm on the pill, my doctor gave them to me because its good for my skin"
yeah.. it keeps girls from getting stretch marks. haha! get it?
....do you get it?
Old November 10th, 2008, 08:52 PM   #5
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Not many miles.. I would see if the springs were not put in right (settled wrong) or something. Dont think struts would be bad with that many miles...
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old November 10th, 2008, 09:27 PM   #6
neverfastenough1's Avatar
Does look weird. Even your tailpipe seems to be lower on the right than on the left. Welcome to the site.
Old November 10th, 2008, 09:43 PM   #7
2000 GT
Are all your tires the same? Like sidewall width mostly? What if you had different tires on rear and then without thinking had tires rotated? otherwise time to replace springs or check them.
Old November 10th, 2008, 09:59 PM   #8
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
yeah, check your tires and such. What kind of springs did you say that you had? Its possible they are bad springs and settled wrong. I would check the alignment of your frame, while the sn95 might be better than the fox bodies, they are still VERY weak. Get subframe connectors and make sure they are installed correctly. Then check your springs.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old November 10th, 2008, 11:26 PM   #9
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
My car does it too, it pisses me off. I tried swapping the ISOs and springs from each side and it still does.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old November 11th, 2008, 12:10 AM   #10
BlckBullitt01's Avatar
TT Bullitt
BlckBullitt01 is on a distinguished road
It shouldn't be too hard to trace down the cause of the problem. Either:
Your frame is twisted, highly doubt, unless you are pushing alot of HP (which I don't believe you are) or the previous owner was in a wreck/jacked the car up wrong.
The spring was installed incorrectly (most likely). I would definitley jack the car up and take a look at both springs. Could be that it is just a faulty spring.
It could be some other things, different size tires, bent control arm, etc. But I highly doubt that it is any of those things.
Old November 11th, 2008, 12:13 AM   #11
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
get that fat dead body out of the trunk an it wont sag to one side...
Old November 11th, 2008, 10:09 AM   #12
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
with 15 miles on it id have to lean toward an issue with the springs. did you look into that first? i doubt your frame is bent unless you did some crazy shit to it. how did you get the car as a second owner with only 15 miles on it?
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Threads Similar to: Help: 99 GT leaning
my car be leaning RhadCundell V6 Mustangs 31 January 2nd, 2008 02:17 AM
car leaning to the left 5mustang0 2.3 Mustangs 55 July 13th, 2007 02:15 PM
Leaning out - upper rpms? blakeasaurusrex 96-98 4 July 3rd, 2007 12:58 PM
2 question about Air/Fuel leaning out... Bossman 2005 - 2010 5 February 9th, 2007 08:46 PM
