1999 Mustang GT
13.8
idleing problems still
I know ive posted this before basically, and have been trying to figure it out through others posts, but when i stop after the engine has warmed up the car basically dies, then jumps to about 3 grand, then dies again, then jumps etc... I have gone through alot of posts and had some good ideas, seemed alot of it pointed to the IAC, but mine is new, and also swapped the one from my 01 gt just to make sure the replacement wasnt a bad part. And it is still doing the die, rev thing. Any suggestions? Mine is a 99 gt and I can swap parts off the 01 for it since I dont drive the 01 anymore. I was thinking of this weekend doing a full tune up new plugs, fuel filter and maybe if people thing it might be fuel system related swapping out hte injectors as well, but would like some more input in case someone thinks of something it could be thats an easy fix. Other than the idle thing, the car runs great, no hesitation, no missing, no blowby and starts up withing 3 cranks of the strater, even better than to 01 wich has much less than half the mileage of this one. I have the k&n listed in my sig, but already swapped out the whole unit from the 01 just to see if the maf or anything had anything wrong but still does the idle die, rev just the same. So basically I know for sure its not maf or iac involved any other suggestions would come in great right now cuz next weekend I am heading to the U.P. and thats about a 1k mile round trip and really dont want to have to deal with the car dieing and revving itself up everytime I stop.
99 forrest green vert: -Diablosport Predator & Tune (removed for cheap gas use) -Motive 3.90 gears -MRT Catted H -Flowmaster American Thunder catback -Eibach Sportlines -Tokico D-Spec shocks & struts My Garage |
1997 Mustang GT
13.56@102.94
![]() iTrader: 1 reviews
Try the TPS sensor from your other car and make sure it's setup and reading proper volts to the wire. Search out how to install and get the proper reading via a volt meter.
Also check for vacuum leaks around the obvious areas under the hood and vacuum leaks in you fuel system emiss junk. If that TPS won't fix it, the best thing would be getting a sct xcal3 and datalog that joker. Then you can send the file to one of the SCT guys and maybe they can catch something.
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
1997 Mustang GT
13.56@102.94
Oh, and check for exhaust leaks where your headers meet the H pipe, etc.
I had got under my car once and the bolts on my BBK headers to H pipe had worked loose on the drivers side.
1999 Mustang GT
13.8
well i dont have headers but there is a slightly noticable exhaust leak, ya think maybe that could cause it?
1997 Mustang GT
13.56@102.94
Yep! It will screw up your O2 sensor readings.
1999 Mustang GT
13.8
even with the o/r h pipe, with mil eliminators?
1999 Mustang GT
13.8
thanx for the ideas though, i will do the tps thing probably tonight after work
Threads Similar to: idleing problems still
| Idleing and rev probs | M0T0PSYC0 | 99-04 | 4 | May 15th, 2008 04:16 AM |
| Idleing and rev probs | M0T0PSYC0 | 99-04 | 4 | May 12th, 2008 01:40 AM |
| Problems (Idleing) and Accelerating) | Darkside_03_GT | 99-04 | 10 | December 19th, 2007 06:34 AM |
| Stang Stalls while braking and idleing | Tscott | 99-04 | 10 | January 16th, 2007 10:01 PM |
| 89 LX Idleing Funny Please Help | Steves LX | 5.0 Mustangs | 4 | December 28th, 2006 05:29 PM |
