Discussing Major Problems, Need Help in the 99-04 Forum. I have a 99 GT with nothing but a BBK cold air intake and an ...
Old October 29th, 2006, 03:53 PM   #1
Look Ma! My First Post!
I have a 99 GT with nothing but a BBK cold air intake and an off road H-pipe. Every time you give it more than half throttle it starts to bust out and it sounds like its starving for gas. It only does it when it reaches its normal operating temp. When it is below 190 degrees it runs fine. Already reaplaced MAFs and got some mil eliminators for the off road H-pipe
Old October 29th, 2006, 03:58 PM   #2
try changin the spark plugs
2002 GT
K&N CAI
O/R X-Pipe
Race Bullit Mufflers
SCT Xcal2 w/Custom Tune By RWTD
4.10 Rear
Nitto D/R's
FR500 Rims 17x9 17x10.5
http://i118.photobucket.com/albums/o...ver/cpsing.jpg
Old October 29th, 2006, 05:12 PM   #3
mjkids's Avatar
i have a bbk on my car with a x pipe but i run a 160 t. the cool the better
2000 ford mustang gt convertible
2004 ford lightning truck
2001 ford mustang/cobra
2008 ford f-350 4x4 truck
Old October 29th, 2006, 05:21 PM   #4
Well to a limit... The engine has to be so hot, or it will burn excessive fuel, and not run its best
Old October 29th, 2006, 06:00 PM   #5
mjkids's Avatar
my runs great at 160 temp
Old October 29th, 2006, 07:38 PM   #6
Check to see if the filter element is real oily, if it is, clean the MAF you may have oil in it causing a misread after the car warms up. Seen it a few dozen times with K&N filters and a few others as well.
Also on a a note built54 is correct the engine needs to be hot and the factory tune is set to run better at 190* than it will at 160* without proper tuning. The factory setting allows more fuel and less timing in closed loop(cold) and at the proper temp returns to open loop adding timing and leaning the A/F . Colder is not better , even tuned you'll see maybe 1-2 rwhp on a dyno.
Old October 30th, 2006, 02:33 AM   #7
K&N
My 95 GT did that shortly after washing my K&N filter. I used an electrical cleaner and sprayed the MAF screen and it worked fine.
Old October 30th, 2006, 11:27 AM   #8
Based on symptoms, and the temp ranges you describe, sounds lean to me. You switch from one fuel table(based on a high or low temp range) to another at a certian point. The low temp range is a bit richer, so I'd be looking for what is modified on your car that could make it too lean. (maf?)
The mention of spark plugs is also valid, as leaner mixtures require more spark energy, and you see the cause and effect here. I run .050 gap on these cars, normally-aspirated(more than .060" is too large a gap to me)
HTH
Old October 30th, 2006, 11:28 AM   #9
Funny, I've seen 4-8hp, dropping the op temps 20-25*, running 180-190* range.
Old October 30th, 2006, 02:27 PM   #10
Thats funny, our dyno showed 2 rwhp peak. Well whatever not going to argue, my point was if you do it get it tuned or it is a waste.
Old October 30th, 2006, 05:48 PM   #11
mjkids's Avatar
all mustang run different from owning four mustang 1979, 1985, 1988, 2000, thats what make mustang one of the best cars for bolt ons
Threads Similar to: Major Problems, Need Help
!!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!! Hububula 5.0 Mustangs 15 May 28th, 2008 10:00 AM
!!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!! Hububula 5.0 Mustangs 3 June 6th, 2007 10:30 PM
MAJOR TRANNY PROBLEMS! Jeff99gt 99-04 13 May 9th, 2007 01:37 PM
Hydroboost Major Problems, Ehhh?? Invictus 99-04 8 February 20th, 2007 05:01 PM
Major engine problems, please help! 03 R Code 99-04 6 August 25th, 2006 05:39 PM
