LinkBack (8) | Thread Tools |
#1
02 Mustang GT
17.8@52
![]() iTrader: 1 reviews
throttle body and plenum
Well its going on 3 weeks of having my throttle body and plenum installed and it sticks at 1500 rpm's until I come to a full and complete stop. The guy at Ford said its because I took off the TPS and didn't line it up correctly because it runs off of micropulses or something along that line...Is this true before I take it to Ford to have it fixed??
![]() NEXT TO SEX, MY MUSTANG IS BEST |
2004 Mach One
you can do it yourself you did it before. Take it apart and clean it, put it back properly
02 Mustang GT
17.8@52
Alright i didn't know they said they needed to hook up a voltmeter to it. If that was the case my buddys a service writer at Ford so I get all the work done for free..
2000 Mustang Gt
technically the TPS in our cars are non adjustable, but you can take a a drill and 'oval' out the holes in the TPS sensor so you can adjust it. I am thinking your problem is something else...
![]() Tuned by Joe at Tricktuners.com |
2000 Mustang Gt
I ovalled out my TPS sensor so I could adjust it with a voltmeter, but all it really did was give me quicker throttle response
02 Mustang GT
17.8@52
alright, well then any other ideas its kinda getting annoying lol
2000 Mustang Gt
maybe your speed sensor located in the transmission. your computer uses that so it knows your RPM vs the speed of your car. Just an idea, but you said it started when you added the plenum and TB, so maybe someone else will chime in.
2004 Mach One
What kind of Throttlebody/plenum did you buy. I hear BBKs stick.
Mine stuck for a day or two, ever since then its been 100% fine. try this?! clean the maf and filter too. Problem starting my car (won't idle) |
02 Mustang GT
17.8@52
C&L plenum and i dont know what TB i bought it off of a guy at the track....
2004 Mach One
What does it say on the actual TB. For example the stock one had the pony running.
Maybe your throttle cable isnt 100% right. Cheap, worn down part, maybe needs cleaning. It could be a few things. |
#11 | |
"Adjusting" the TPS on a EEC-V engine will accomplish nothing as the PCM constantly reads the TPS ouput and saves the lowest value it sees as the closed throttle value.
Since it knows the angular rate of the potentiometer that is the TPS it can calculate the throttle position at any time using the known rate of change, current output voltage, and saved "closed" throttle voltage. Returning to the OP's idle problems, the "hanging" idle until the vehicle stops is normal however it's normally only at 1000 to 1100 rpm. 1500 is high. The reason for this is to ensure adequate power steering fluid pressure for the power brakes. Have you tried disconnecting the battery for 5 -7 minutes? Doing so will clear the KAM (Keep Alive Memory) which is where the PCM stores learned values like the idle air trim, used as a reference for all idle control functions. Resetting the KAM will force it to relearn these values. This is from the shop manual and may be of assistance:
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
#12 | |
FWIW I went through this with an Accufab 70mm combo on my 2003 automatic and eventually ended up sending it back because the idle hang drove the automatic tranny crazy when coming to a stop. Sort of like stepping on the gas and brake at the same time. My car is complete stock except for a Magnaflow catback. I found out later that this is a very common problem and that their is a parameter called "return to idle" or something like that which can be changed via a tune and will solve the problem. For the record, everything was installed fine on my car, no leaks, no binds, reset the KAM etc Some cars just have this problem and others do not. Some cars fix themselves after a week or so of driving, mine did not. Automatics seem to be more prone to this from what I can tell so I suspect maybe it's related to firmware in the PCM being different on various cars. I don't know. |
Threads Similar to: throttle body and plenum
| plenum/throttle body | Jucostud | 96-98 | 11 | February 19th, 2008 12:19 AM |
| Stock Throttle body and plenum | G.T. Rags | 96-98 | 2 | November 2nd, 2007 06:24 PM |
| PP Throttle body/plenum ? | auburntiger7231 | 99-04 | 10 | October 12th, 2007 08:56 PM |
| throttle body and plenum HP | Cantbeatblack | 99-04 | 16 | October 1st, 2007 10:51 AM |
| THrottle body and Plenum question | Cantbeatblack | 99-04 | 3 | September 24th, 2007 01:35 PM |
