update on idleing probs - still doing it
Old May 17th, 2008, 02:16 AM   #1
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
M0T0PSYC0 is on a distinguished road
Ok as i had mentioned before my car after warmed up drops to die then jumps itself upto about 3grand then does it all over, I have gone through all the iac stuff no change, havent messed with the tps yet, but did get new plugs, now the others had been in for awhile and the guy who owned it must have not done it right cus they were gapped at .040, i installed the newones at .052-.056. definatly ran smoother but the prob is still there basically. Except now it just dies and dont jump upto 3 grand, however no when in nuetral with no load basically with clutch out it dont die, were before it still would, so I think im on the right track but could use a few more ideas. And the car has always had premium in it so the injectors shouldnt be too bad at 133k miles though. I dont think its the coils cuz the car doesnt miss or hesitate, however if this helps draw any ideas the car bucks alot from takeoff-3rd gear, and that is annoying as hell in itself, so i think these probs may be related but havent a clue on this one. please help guys
99 forrest green vert:
-Diablosport Predator & Tune (removed for cheap gas use)
-Motive 3.90 gears
-MRT Catted H
-Flowmaster American Thunder catback
-Eibach Sportlines
-Tokico D-Spec shocks & struts
My Garage
Old May 17th, 2008, 02:19 AM   #2
00silvergt's Avatar
2000 Mustang Gt
00silvergt is on a distinguished road
did u just clean the IAC or did u replace it? it might be beyond cleaning.
Tuned by Joe at Tricktuners.com
Old May 17th, 2008, 02:22 AM   #3
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
it was new when i got the car, and laso swapped in another one i knew was good in case it was a bad replacement part, but did it just the same, although definatly runs smoother with the new one, but no change with the dieing and bucking issues
-Motive 3.90 gears
-MRT Catted H
-Eibach Sportlines
My Garage
Old May 17th, 2008, 06:01 AM   #4
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
ok, well i eliminated the tps idea,swapped that out, still the same, any good suggestions guys? I really need some help with this. It's my daily driver but not so much of a driver if its gunna die every time I drive. also I swapped out the k&n cai for the stock unit including cleaned maf also so that wouldnt be the prob either.
-Motive 3.90 gears
-MRT Catted H
-Eibach Sportlines
My Garage
Old May 17th, 2008, 06:04 AM   #5
MineralGreyGT's Avatar
MineralGreyGT will become famous soon enough
did you try checking your MAF housing for any cracks, or cleaned the MAF? I had a similar problem but I have a 5-speed and it ended up being a crack in the MAF housing and air was being drawn up from to different locations and was throwing my MAF out of whack.
http://img192.imageshack.us/img192/9175/sig1xts.jpg
Old May 17th, 2008, 06:06 AM   #6
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
thats all fine and I have a 5-speed also
-Motive 3.90 gears
-MRT Catted H
-Eibach Sportlines
My Garage
Old May 17th, 2008, 07:53 AM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Try spraying some brake cleaner on some of the vacum lines to check for leaks, it will rev up if there is a leak when you hit it with the brake cleaner.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old May 17th, 2008, 10:40 AM   #8
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Have you disconnected the battery for 5-7 minutes, to reset the KAM (Keep Alive Memory)?
The KAM is where the PCM stores all learned values, including idle air trim, short and long term fuel trims, etc)--resetting it causes the PCM to relearn the values.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old May 18th, 2008, 01:49 AM   #9
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
I am gunna check for vaccum leaks tonight, and as far as battery disconnect, whenever I am swapping stuff around to check it out i always leave disconnected for at least 20 minutes, but usually 30 or more
-Motive 3.90 gears
-MRT Catted H
-Eibach Sportlines
My Garage
Threads Similar to: update on idleing probs - still doing it
idleing problems still M0T0PSYC0 99-04 6 May 16th, 2008 01:15 PM
Idleing and rev probs M0T0PSYC0 99-04 4 May 15th, 2008 04:16 AM
Idleing and rev probs M0T0PSYC0 99-04 4 May 12th, 2008 01:40 AM
Pro 5.0 shifter update/vid update 07stanggt 2005 - 2010 43 February 29th, 2008 10:17 PM
89 LX Idleing Funny Please Help Steves LX 5.0 Mustangs 4 December 28th, 2006 05:29 PM
