Improve Performance on my Stang
LinkBack (1) Thread Tools
Old May 19th, 2008, 04:28 PM   1 links from elsewhere to this Post. Click to view. #1
roush284 is on a distinguished road
Hey Guys -
I recently installed the motor back in my 2000 Roush Stage 2. I had the motor rebuilt with all forged internals to increase the boost of the vortech. Im now running a vortech s-trim with 10-12 lbs of boost, pulley(not intercooled). I also installed some BBK ceramic headers, a pro 5.0 shifter, and 30lbs fuel injectors. Im looking to get better low end performace to match the excellent top end provided by the supercharger. I currently have the roush exhaust, that came stock on the Stage II(with cats), I beleive its borla. What would the best bang for the buck to get increased low end perf. and get me into 12 second 1/4 mile times with my setup? The roush suspension is also adjustable, and I would like some advice on the best way to adjust this for running the 1/4 mile. Ive also heard great things about MSD ignitions.. Thanks for any advice on this!~
Larry B.
Old May 19th, 2008, 04:49 PM   #2
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
You ran forged internals to only push 12lbs of boost?
2004 GT Boosted by Vortech
Old May 19th, 2008, 05:14 PM   #3
Well its easy enough to swap out the pulley, and doesnt hurt to have forged, if i decide to up the boost in the future. Its still a bit sluggish off the jump though. Do you think cutting the cats or opening up the exhaust to 3" would help on the low end?
Old May 19th, 2008, 05:14 PM   #4
2000 mustang gt
marcd is on a distinguished road
get bigger injectors and turn the boost up
Old May 19th, 2008, 05:23 PM   #5
Garhfer's Avatar
Dude with 12lbs of boost you should already be in the 12's, you probably just need to learn how to drive the car, tune the suspension right and get some nice tires, but definitely up the boost I hit 12 lbs of boost on hard runs and I have stock internals, since you have forged you might as well use them.
Old May 19th, 2008, 05:24 PM   #6
Russ 3 ll PGT is on a distinguished road
Send a message via AIM to Russ 3 ll PGT
I would definitely drop the Borla exhaust and cats that came on the car initially. Borla, in my experience, is a quality exhaust - but it's nothing more than a higher quality stock exhaust. I'd get yourself some bigger piping to free up some backpressure, especially with that blower. And, of course, up that boost!
Old May 19th, 2008, 06:10 PM   #7
My best time prior to all these enhancements was 14.46 at 102 mph... this is of course at 6000 ft, Bandimere. And was with the 4-6 lbs pulley, but stock internals. Maybe I need some tips on how to launch the thing, I get excessive wheel spin usually through first gear.
Old May 19th, 2008, 08:10 PM   #8
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
If I understand correctly, you were running non-intercooled 4-6 lbs of boost with 30 lb injectors. You're now up to 12 lbs non-intercooled and still running 30 lb injectors. I'm running 8 lbs intercooled with 42 lb injectors. Are you sure your injectors are large enough for your setup?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old May 19th, 2008, 09:30 PM   #9
superbeef1000's Avatar
some gears could help the low end if you dont already have some
Old May 19th, 2008, 09:42 PM   #10
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
Well before you go adding more power...you really need to focus on your suspension and maybe some racing schools...even at higher altitude you should be getting better times then that.
Also I personally would not run anything more than 10 psi (and thats really pushing it) without an intercooler or aftercooler. You can pick up a set of used 42# injectors and larger MAF for around $250.
Old May 19th, 2008, 10:29 PM   #11
2002 mustang gt
13.5 @ 106
mustangjl is on a distinguished road
+1 on the intercooler b/c its better for your pistons. and you can run more boost. and you need bigger injectors
mods: flowmaster catback,75mm tb,3.73,sct x3,turbo 70mm-10psi,3 core intercooler,injected engineering tune,mph blower cams. 450hp/460tq
fastest et 13.3@114
bowties are for little boys
Old May 19th, 2008, 10:46 PM   #12
Thanks for your responses. Im gonna take your advice and go with some 42# or larger injectors, also im gonna look at replacing the MAF, and eliminating the cats...
As for the intercooler, is it better to run air-to-air or air-to-water, and can i get a setup for the 2000 style, that bolts on in front of the radiator? Ive only taken the car down the strip a total of 3 times... thanks again for your help!
Old May 19th, 2008, 10:51 PM   #13
dude496's Avatar
04 Mustang GT
It has a lot more to do than just being safer on a motor....plus his car is forged so it can handle some abuse. The reason you need a cooler is because of the heat generated by the supercharger...you need to cool down and further condense that air to make the most use out of it. 8 PSI its not really necessary for a cooler, but even at that low boost still recommended. Once you start pushing 10+ you really need to get that air cooled down
Old May 20th, 2008, 12:28 AM   #14
94pacecarSVT's Avatar
11.2@122.36
94pacecarSVT is on a distinguished road
Send a message via AIM to 94pacecarSVT
hey roush284 how much did you pay for your internals, and where did you buy them? i have a 2000 motor in my 96 and im lookin into getting forged internals so i can run 16psi.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.
www.rk-collection.com
Old May 20th, 2008, 12:31 AM   #15
Proud American
MustangMatt96GT's Avatar
12s at this altitude 5800 FT where i run and he runs is not easy. But you should be able to do 12s with a full suspension and 450 RWHP. I would get 42# injectors too. And turn up the boost, but mainly redo your suspension and get some sticky tires...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old May 20th, 2008, 12:46 AM   #16
11.2@122.36
wow altitude makes way more of a difference then i thought. i run mid-low 11's with 441rwhp and 3.73's in concord, nc which im not sure of the exact altitude here. but its not near as high as where yall are
Old May 20th, 2008, 09:42 AM   #17
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Spray a 75 shot through the MAF. That should wake the car up....
Old May 20th, 2008, 10:32 AM   #18
Avaric3's Avatar
2002 Ford Focus
slow as fuck
Avaric3 will become famous soon enough
opening up the exhaust would make you lose some low end power. the best thing for a low end kick would be gears and for your car id say 3.73s
99 V6 Mustang-sold
02 Ford Focus-sold
98 Camaro Z/28-lid, catback
Old May 20th, 2008, 11:48 AM   #19
yojoe600's Avatar
yojoe600 will become famous soon enough
I have heard it was better to run an air to air intercooler
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Old May 20th, 2008, 11:56 AM   #20
Im running the Manley Forged 11cc Dish Piston .020 Over, $578 for the set... The Eagle H-Beam connection rods - $545 EAGCRS5933F3D for the set. The heads where ported and polished, the flywheel balanced, and crankshaft was honed. I went with Geddes Auto Machine shop out of colorado springs, to do the work... The first time I put the motor back in.. it was losing compression on the 1, 3, 4 and 8 cylinders, so I had to re-pull the motor, and they rebuilt it... This time around everything seems to be up to par, ive only had it back in since Saturday though.. Now Im looking for ways to protect my investment in this motor(intercooler and injectors seem top priority).
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/71744-improve-performance-my-stang.html
Improve Performance on my Stang This thread Refback May 20th, 2008 12:33 AM
Threads Similar to: Improve Performance on my Stang
99-04 stang performance book DeMello 99-04 19 April 21st, 2008 12:52 PM
15.5 mpg - How can I improve this? Disturbed One V6 Mustangs 20 February 16th, 2008 09:24 AM
The Clueless Performance Shop and my V6 Stang SonicStang V6 Mustangs 14 May 24th, 2007 01:35 AM
Can this improve performance? stagecrewgod V6 Mustangs 7 April 5th, 2007 06:00 AM
? on performance parts for my V6 stang 3.9V6mustang V6 Mustangs 10 August 23rd, 2006 10:34 PM
