Well guys I did some searching and found some threads about people with bad throwout bearings and such but alot of them where confusing, 1 thread had something about you could tell the TB was bad when the clutch was pressed in, the other thread was saying the opposite, well I noticed today a weird ticking noise with the car in neutral and ebrake pulled, my stepdad said it is prob my throwout bearing, if i just barely touch the clutch, not even trying to push it, it stops, could this possibly be something else? Any info would be great guys.
As far as I know, your TOB squeaking isn't all that bad. If you decide to replace it you might as well replace your whole clutch because you're gonna have to take it out regardless. Labor at a shop is gonna cost you, but I see you're gonna do it with a friend so good luck!
well a shop said 300 for the install of the clutch and he would throw my aluminum driveshaft in for nothing extra since its out anyways. but im just curious about what setup to go with ... id kind of like the lifetime clutch warranty from autozone or something and maybe a fidanza or w/e aluminum flywheel, would that be a good setup?
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
