Lowering Springs
I am going to have a shop lower my car. When looking at everything I just need to get a set of lowering springs right? Just buy the set of 4 springs and they could reuse everything else with no problem?
11.47@120.58
Depends on how low you go. Anything around 1.5" or lower would require caster / camber plates and aftermarket shocks / struts.
are you sure about that man? lots of people get a drop alittle lower with the H & R springs around 1.7 and they just get the cast chamber 4 bolt plates. dont need new other things.
RLY SRS
They dont have to use them...But it is highly reccomended...Lowering a car with stock shocks/struts and with C&C plates is doing things half-@ss...
Eibach Pro kit and Steeda Comp springs are about the same...1.5-1.7 inches... Eibach Sportlines lower the car around 2 inches all the way around... If you lower the car with the stock springs and shocks they will wear faster...If you dont use C&C plates it is going to be tough to get your front end alighned perfect... |
I dropped mine 1.5 with Eibach Springs and still bought the camber plates to be on the safe side. Might as well do it right the first time.
i like the eibach pro street -s system its a bit more money but worth it im sure
i have eibach pros on my car like chrisj said i agree put the shocks, sturts,and i put the front and rear sway bars steela if you are going to do it do it right you will be happy
![]() 2000 ford mustang gt convertible 2004 ford lightning truck,,,,,sold 2001 ford mustang/cobra,,,,sold 2008 ford f-350 4x4 truck 1989 ford notch back 5.0 2006 custom build bobber |
Ok so its a yes and no... Yes you CAN do it with just springs, but for the sake of my car lasting and performing, I should go ahead and do it right the first time...Thanks for the input guys....
ehhh i just cut my stock springs and had it aligned with camber bolts,didnt need CC Plates but i could use em...my car dropped a little lower than 2" i think,cause one of my friends stang has sportlines and mine was lower...and the ride is not bad,it only feels stiffer on pot-holes but other than that its smooth!
![]() Stock w/Flowmasters
Threads Similar to: Lowering Springs
| lowering springs | mrnewall | 99-04 | 7 | May 6th, 2007 02:03 PM |
| Lowering Springs | energiesource | 99-04 | 13 | April 30th, 2007 12:04 AM |
| lowering springs | scxc15 | V6 Mustangs | 5 | April 5th, 2007 08:41 PM |
| Lowering Springs | sonicblue | 99-04 | 5 | October 12th, 2006 01:41 AM |
