Forged pistons and rods only?
Old May 24th, 2008, 12:31 PM   #1
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
I can get my hands on a 4.6 2v core. Could i just go with forged rods and pistons since these are the weakest links? I just want to have a backup motor since i am putting this SC on my car. Are our factory heads very weak? i dont wanna spend much on a "extra" motor. ya know? Or would it be pointless to half way do it. Im not pushing my motor over 420 hp anyway. and if something was to happen to this one i would just drop another one in. Im not really looking for a 600 hp car at the moment. It is a daily driver so i wouldnt ever want more out of it than those numbers.
Old May 24th, 2008, 12:37 PM   #2
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
The stock crank is good to about 600 rwhp. If you only plan on going to 420 rwhp, then the crank will me fine. The pistons and rods can handle that much too, but it's reaching their limit. It would be safer to replace them. If you do eventually plan on making big power though, you might want to replace the crank now with the pistons and rods. It's so much easier then crackin' open the motor again just for a crankshaft...
So I don't focus on my mistakes. What keeps me going? I look in the mirror and I am PROUD that I will do WHATEVER it takes to provide for my family. Whatever it takes.
Old May 24th, 2008, 12:40 PM   #3
What do you mean by this? The heads have really weak flow if that's what you mean. No real huge amount of stress is put onto the heads themselves so they don't need to be very "strong". The components that are contained in the valves are put under stress though (valves, springs, etc...) and need to be replaced when you start making big power or reving beyond 6200 rpm. For 420 rwhp the stock heads and components will be fine though.
Old May 24th, 2008, 12:43 PM   #4
BakerFX4's Avatar
iTrader: 14 reviews
aight cool. Yeah im sure that im not going to ever go above 450 ever. i dont want to aim for 600 hp at all. I put alot of money in my FX4 Screw w/20's 36's and 9" lift. so the mustang cant be my only toy taking every bit of my money. ha
Old May 24th, 2008, 12:51 PM   #5
TheUNZippee!'s Avatar
Famous last words^
Originally Posted by My Wife
Old May 24th, 2008, 02:21 PM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the crank will hold well past 600, it will hold well past 800 if treated. the rods are the biggest thing, when they let go it usually isnt pretty. the pistons are just fine for all n/a or small power adder, it depends on how you set it up. the VE of the modular ford 2v heads is not great, the intake valve is only 1.75in and is primary restriction. with some work you can make them flow decent, but still limited. there is not any aftermarket head casting for the 4.6 either, all aftermarket heads are ford heads.
Threads Similar to: Forged pistons and rods only?
pistons and rods 4.6 94stang 99-04 26 February 19th, 2008 06:46 PM
pistons rods Bhblondguy 2005 - 2010 11 November 7th, 2007 05:46 PM
Pistons Rods Bhblondguy 2005 - 2010 3 November 7th, 2007 01:50 PM
Pistons Rods Bhblondguy 2005 - 2010 0 November 5th, 2007 10:08 PM
pistons and rods on the cobra... WVSNS& 99-04 3 March 10th, 2007 08:11 AM
