Bad Noise after cam install, can you say bent Valves
Yeap, you guys got it. We did the compression test and the intake valves on that side are leaking. We are getting new ones on monday. I have a question. Can I reuse the head gasket or is it already wasted?
2002 GT SOLD 2003 Mustang GT Cobra Clone SOLD Procharged @ 8psi 458 rwhp ![]() Mods in Garage
Never reuse a head gasket, it has already been compressed. No shortcuts at all, I never reuse any gaskets, NEVER.
I thouth so, was just making sure. Anyone know were I can get one side gasket only. And were can a I get a good degreein kit at a good price?
you need to replace head gaskets,,and head bolts...so what are you doing about pistons...
What do you mean? If Im changing pistons for clearance? If its that then no, we are getting it degreed.
Anyone know were I can get a single head gasket
13.1@105
![]() ![]() iTrader: 7 reviews
i'm almost positive that the pistons are tweaked when then hit the vavles.......but maybe i am wrong
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees! |
happens a lot that when the pistons slap the valves, the pistons are also can get some damage
I know, we checked but there was only one valve that was bent. The others hit the piston too but werent bent. Either way we are changing the 4 intake valves. The mark is less than a 1/4 of an inch.
your troubles are not over yet...
change all valve, and i bet the pistons are hurt also. like tom said, your troubles are far from over
#12 | |
You couldn't have said it better, the force of ptv is just as bad as detonation. I wonder how those rod bearings look, time bomb ?
I pull it out,bore it 20 over,use stock crank ,,scat h-beam rods,,new forged pistons...then down the road he can add, nitrous,,supercharger,,turbo...
thats why doin g things the right way in the beginning save lots of time and money and make for a better day overall lol
oh my gosh, i just saw the video. that engine is screwed man
1997 Mustang GT
13.56@102.94
![]() iTrader: 1 reviews
Where is the link to said thread with vid?
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
FYI, the engine is not screwed, only one side of had ptvc problems. We took the head off, were changing the 4 intake valves on that head since they were the only ones that hit, even though only one was bent. It was not bent badly. It was not even noticeable until we got it off the head. We took the pistons out yesterdady and they all look great. There was no damage to either one of them.
if thats the case, you are so freakin lucky its rediculous
Threads Similar to: Bad Noise after cam install, can you say bent Valves
| Bad noise after cam install. Help | andres0286 | 99-04 | 109 | May 24th, 2008 10:14 AM |
| bad noise... | 01GT | 99-04 | 8 | July 9th, 2007 08:26 PM |
| What is the Biggest cam with 202 valves on stock pistons | Kevin b | 5.0 Mustangs | 7 | January 3rd, 2007 12:21 AM |
| Cam And Heads Installed Now A Wierd Noise From Intake? | Sable | V6 Mustangs | 12 | September 11th, 2006 07:38 PM |
| Head install question: Setting valves before starting? | mikes93fox | 5.0 Mustangs | 3 | August 28th, 2006 10:50 PM |
