Need help jumping time
Old May 25th, 2008, 02:56 PM   #1
Yella01Stang's Avatar
Yella01Stang is on a distinguished road
I have an 01 gt and when I was installing my new engine I was hooking up the stuff under the car while some friends were up top...wll one of them didnt take the time to make sure all the coils were in the right position so one was tucked in between the head and lower intake and then once tightend down broke off and fell down the intake port, tried to start it and it was locked down...took the intake off and pulled the rubber boot out between the valve and valve seat...it was then out of time and with a compression check the valve wasnt bent. so I took it all apart and re timed it and it rolled over fine by hand so i put it back together and then I tried to start it and it had piston to valve hitting...like something is messed up to make it jump timing so I then replaced the timing chains and It did it again??? If anyone has any insight to what this might be it would be greatly appreciated.
2001 GT Stang
"Bullitt #5583 wanna-be"
Best ET 13.8 104mph (b4 motor/gear)
D.S.S. ProMod ShrotBlock, DiabloSport Predator,
Steeda TriAX, FRPP 4.10s & D-shaft, FRPP 24# injct,
Flowmasters, 03 Cobra Brakes, one awesome
tune & much more ;]
Threads Similar to: Need help jumping time
engine jumping around bad :[ emgjsdk1 99-04 3 February 16th, 2008 06:55 PM
Time Jucostud The Clubhouse 2 November 4th, 2007 01:06 AM
New member first time poster long time fan kpmorris New Members Introductions 14 August 19th, 2007 11:53 PM
car jumping a fence fogged306 The Clubhouse 11 July 15th, 2007 08:24 PM
rpms jumping jh3rlh 5.0 Mustangs 4 March 26th, 2007 02:08 PM
