Engine Oil Dipstick Install - Forums at Modded Mustangs
post #1 of 5 Old May 25th, 2008, 05:14 PM Thread Starter
Exclamation Engine Oil Dipstick Install
When i put longtube headers on in the fall i broke my oil dipstick tube trying to bend it around the new, larger primaries. Since then i bought a OEM replacment, but had to bend it differently to go around the headers again and it crimped from vice grips at the entry point into the pan. Now i cant get the stick in. So, i finally got a flexible tube with stick and im gonna install it soon. I was curious if anyone has any tips or ideas how to make removal of the old and installation of the new a little smoother, because it SUCKS trying to yank them out then jam a new one in!
quiksilver225 is offline
post #2 of 5 Old May 25th, 2008, 08:00 PM
mpboy's Avatar
dude im not going to bull shit you, i took my engine and trans out, too my drive shaft off and installed new u jounts. rebuilt the entire motor in my living room and reinstalled the engine and trans... all by my self. but then the dipstick broke.... i beat on it for 2 days trying to get the new one in... that little oil dipstick beat my and made me an epicfailpw3ndjackass. so my advice is to take it to a shop, they did my in 20mins. thay have done it befor and they have the right tools
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
mpboy is offline
post #3 of 5 Old May 25th, 2008, 08:06 PM
mpboy's Avatar
but to answer ur ?, it would be a lot easier if you take the motor mount off, jack the motor up on that side, loosen the header and it gives you a lot more room to slide it back there into the block, but becarful bending and crimping them, there bent that way for a reason, and if you get a crimp in there the indicator will be a PITA to slide down into the tube. the old one will come out with a little twisting, the new one is a press in so it presses into the block, and make sure the o ring is on the new dipstick. also prepare to change your oil, because you will need to remove the filter to give you room to work, and any shit that falls down into you oil pan needs to be gotten out.
mpboy is offline
post #4 of 5 Old May 26th, 2008, 01:52 PM Thread Starter
the oil filter isn't a problem and it it isn't worth taking the headers off to do. I had the idea of getting the block up to opperating temp and then i put the new tube in the freezer for a day. The freezer trick definatley helps, but not as much as id like it to. Also, i asked a Ford mechanic what they do and he said they just torch the block to heat it up, then just force that thing in there.
Any other ideas???
post #5 of 5 Old May 26th, 2008, 05:07 PM
mpboy's Avatar
yea heating it up helps, my guy said he uses a tool that goes around the lip of the dip stick that sits on the block and taps it in with a hammer, sry i cant be more help, but those dipsticks are a pain man, if u come up with something let us know
mpboy is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/72715-engine-oil-dipstick-install.html
Install Dip Stick Tube This thread Refback March 1st, 2013 05:19 PM
engine oil dipstick install - Zuula Search This thread Refback September 22nd, 2009 01:02 AM
oil dipstick install - Zuula Search This thread Refback September 14th, 2009 12:34 AM
