Discussing Axels and rear end. in the 99-04 Forum. Looking at 31 spline Strange Axels and Detroit True Trac. Does anyone know any reason ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Axels and rear end.
Does anyone know any reason that I should avoid either of them? Also, besides wheel studs, are there any other parts I need to do the swap?
http://www.shaunhamptondesign.com/Sigs/FS01a.jpg |
might as well change all the bearings and seals. gear oil, and not sure if the trutrac needs friction modifier
'96 Exploder XLT 5.0 AWD "turbos coming soon" |
They'll be fine. I agree if there's alot of miles on the car, go ahead and repl all the bearings. I 'm using a 33spline Auburn Pro Diff and Moser axles. If ya want to go that route, I've got a new set of 33spline axles w/ the clip eliminators already installed. I'll make ya a deal on them
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
#4 | |
Would the C-clip eliminators work with disc brakes? How long would an auburn diff last with hard launches? I've heard some horror stories.
yep, 99+ and 3"studs. The Pro-series diff according to the guy at Auburn is good for 1000hp in the 33spline version.
Maintenance Man
11.47@120.58
I run Moser 31's and an Explorer trac loc. I wouldn't worry about C-clip elims unless your drag racing and it's required. I wouldn't worry with the bearings etc. on your late model. Make sure you get the axles machined for ABS rings if your gonna keep them.
the bearings are cheap replace them, better than having to tear it back apart in 2 years to do it again.
Threads Similar to: Axels and rear end.
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 13 | October 20th, 2008 03:29 PM |
| when replacing axels | matfernan1 | 99-04 | 2 | August 10th, 2007 03:21 AM |
| Rear end | mb03stang | 99-04 | 3 | March 3rd, 2007 01:45 AM |
| About my rear end | steven316 | 5.0 Mustangs | 9 | February 15th, 2007 09:52 PM |
| Rear Rotors and Rear Axle | rondaw3g0410 | 99-04 | 1 | September 6th, 2006 11:00 PM |
