return style fuel system conversion
Old May 26th, 2008, 09:37 PM   #1
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
Has anyone done this? what all is involved with it.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old May 26th, 2008, 09:46 PM   #2
9Sec03Cobra is on a distinguished road
I have done a few and there are a few ways to do it. What are your intentions with the car?
Sean
2003 Cobra
9.5 @ 146 on radials
Just a few bolt ons with a good tune
04 Mach1
9.78 @ 138.9
Old May 26th, 2008, 10:20 PM   #3
zerofx150's Avatar
2003 GT
13.6 @ 101
well i spray a 100 shot on it and i have been having an issue with the fuel pressure drop on the hit. I am going to do the hot wire mod first and see what happens. I have a bigger pump as well so i also wonder what else it could be that is causing it. what is the fuel pressure at idle and WOT on these cars?
Old May 26th, 2008, 10:24 PM   #4
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
you can just do a dedicated fuel system for the nitrous. i can't believe you are having that much of a problem though cause i was shooting a 150 shot and had the fuel pressure problem for about less than 1 second and then the fuel pump caught up. but you can buy a 1 gallon fuel cell, a inline pump, and fuel pressure regulator and wire the pump to turn on when the nitrous is armed and have the fuel from that small tank feed directly into the fuel sol. But with what you have i doubt that spending over 1k for a returnless fuel system would be worth for what little power you are making.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 26th, 2008, 10:44 PM   #5
Fuel pressure should be around 38-40 psi. Im kind of surprised your having problems with the fuel system at your power level.
2003 Cobra
04 Mach1
9.78 @ 138.9
Old May 27th, 2008, 08:37 AM   #6
I guess you data logged this on the dyno? How big of a drop are we talking about?
Sean
2003 Cobra
04 Mach1
9.78 @ 138.9
Old May 27th, 2008, 09:38 AM   #7
zerofx150's Avatar
2003 GT
13.6 @ 101
well i have never dyno'd it to determine whats going on, i planned datalogging it today but its raining. its just a bad hick-up upon engagement of the nitrous for that very short time and then its fine, but it bugs the hell out of me.
Old May 27th, 2008, 10:47 AM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
If it's a hiccup, it is probably getting fuel and air (from an unpurged nitrous line) on the initial hit. If it was going a touch lean due to fuel pump reaction time, you would not feel a power loss or "hiccup". Most kits have a small lean spike upon intitial activation. There are a few ways to combat this. With a wet kit, you can use a longer nitrous line from your solenoid. I was using a 6" fuel line and a 24" nitrous line at one time, and that took all the spike of a/f fuel ratio. 1100PSI of N2O just travels faster than 40 PSI of fuel. Also, a dry shot can be controlled even better by placing your injection point further or closer to the throttle body.
Old May 27th, 2008, 11:15 AM   #9
zerofx150's Avatar
2003 GT
13.6 @ 101
Well AC thanks for that info, i do have the purge on the car and and purge before the run, he is the question the purge is before the nitrous solidnoid not through it on the back side, would it be better to swap that over?
Old May 28th, 2008, 11:38 AM   #10
MM's nicest mod, :)
yes it needs to be after the nitrous soloniod. Also mine did the hickup thing when i tried it on the street but where it counted on the track it never hickuped at all
Old May 28th, 2008, 11:44 AM   #11
MM's Mad Scientist
acmillr's Avatar
Slow Fella
After the nitrous solenoid? How will you purge it after the solenoid from idle?
Old May 28th, 2008, 11:58 AM   #12
zerofx150's Avatar
2003 GT
13.6 @ 101
i have the NX kit and the nitrous noid if not capped on one side will just blow out the side but once engaged it goes out the bottom port
Old May 28th, 2008, 11:07 PM   #13
It needs to be before the solenoid. If it were after then it would not purge until the nitrous solenoid opened first. You want to get the air out of the line before the solenoid.
2003 Cobra
04 Mach1
9.78 @ 138.9
Threads Similar to: return style fuel system conversion
fuel system sniperrider 5.0 Mustangs 17 March 24th, 2008 06:44 PM
Fuel System?! 1997Stang 96-98 7 January 8th, 2008 08:09 PM
coverting to return style fuel system bcchambe 99-04 0 November 9th, 2007 01:49 AM
302 fuel injection conversion? help 78mach1 5.0 Mustangs 1 October 24th, 2007 03:44 AM
Benifits of return fuel to non return fuel??? JONJON 5.0 Mustangs 4 October 21st, 2007 03:11 PM
