Idling Problems
Hey guys I have a 02 Mustang GT, and the other day I was jump starting another car, with some jumper cables, so I connected everything correctly and the other car started, but then when I disconnected the cable from the other car I accidentally made contact with both cables, and sparks flew. In other word I made a short. All of this happened while the mustang was still connected and the car being on. Then all off the sudden I heard that my car was sounding louder than usual like if I was hitting the gas, but I wasn't. I looked at the RMP gauge and it was at 1 RPM instead of it being at the half RPM that it's suppose to be at when parked. Why is it idling weird? plz help What did I do? Did I mess up the computer?
is your check engine light on?
2001 GT: For Sale, low 13s ![]() 2003 COBRA: 12.11@116 |
may have fried a circuit. have the alternator checked, i've seen an arched battery burn the shit out of the alternator
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
I have another question, could I have damaged my TPS sensor?
i was talkin to a friend of mine last night about that and he said that it could have messed up your tps
there's all types of shit you could have fried. but if it's any sensor it should throw a code. tps wouldn't have to do with idle...check your IACV and clean that and check vacuum lines just in case
Disconnect the battery for 5-7 minutes, the EMI/RFI glitch from the short could have scrambled the KAM (Keep Alive Memory] where all learned parameters (such as idle air trim, short and long term fuel trims, etc.) are stored. Disconnecting the battery for 5 minutes or more resets this memory and forces the PCM to relearn these values.
The TPS has no active electronics (it's just a potentiometer) and is only connected to the PCM and ground. It is highly unlikely that shorting the battery damaged the TPS without taking out the PCM too. Same is true for the IAC. In the last--when using jumper cables; connect both positive cables first then both grounds (battery to be jumped last). In this way there is no common ground between the vehicles until the last ground is connected... When disconnecting do the both grounds first, then the positives. This removes the common ground first. It would also have prevented your faux pas...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
KB'd GT
I wouldn't worry. Many times the car will set a high idle just after the ECU is reset (dead battery). Give it a day or 2 and it should go away.
Threads Similar to: Idling Problems
| idling problem | proracer97 | 5.0 Mustangs | 3 | February 15th, 2008 01:26 AM |
| idling | riddlee josh | V6 Mustangs | 4 | January 14th, 2008 01:09 AM |
| Idling problem | 302pusher | 5.0 Mustangs | 4 | August 1st, 2007 05:57 PM |
| idling | afmustanglover | General Tech | 7 | April 4th, 2007 11:39 AM |
| My 86 idling | 5literJeff | Videos | 1 | January 18th, 2007 06:26 PM |
