vortech mini race? is this it???
Old May 28th, 2008, 09:39 AM   #1
lilmarc1988's Avatar
2001 mustang gt
lilmarc1988 will become famous soon enough
Send a message via AIM to lilmarc1988 Send a message via Yahoo to lilmarc1988
is this a vortech mini race bov? never seen 1 be4. Maxflo Race Bypass Valve, off of jegs.com
Old May 28th, 2008, 09:44 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
a BOV and a bypass valve are 2 different things if that's what your asking.
Old May 28th, 2008, 09:56 AM   #3
2001 mustang gt
damn i meant is that the mini race bpv? and y u change the color of your sig? to not piss a certain some1 off??
Old May 28th, 2008, 10:14 AM   #4
HMUSN's Avatar
iTrader: 9 reviews
if it's maxflow it's made by vortech.
about the sig question.
I haven't touched it in a while.
I could care less who I piss off
Old May 28th, 2008, 08:10 PM   #5
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
The red thing is a Vortech mini-bypass...
A BOV and Bypass are basically the same thing...I used a BOV on my car for about a year...You just have to recirculate it and set the spring right...
Facebook
Google+
Old May 28th, 2008, 08:14 PM   #6
HMUSN's Avatar
iTrader: 9 reviews
something about natural aspiration and our fuel system.. well.. not MY fuel system.. yours
Old May 28th, 2008, 08:24 PM   #7
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
Not understanding this bro...
As long as you recirculate the BOV or BPV back before the supercharger and after the maf then you are fine...They both just release the pressure after you let off the pedal to stop surging...
Facebook
Google+
Old May 28th, 2008, 08:26 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
I thought it had to do something with the whole open loop vs closed loop systems.
feel free to correct as i'm new to boost.
Old May 28th, 2008, 08:28 PM   #9
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
Nah the bov/bpv are interchangeable...As long as they recirculate for those of us running pull through set-ups...With blow-through mafs it is even easier...You can vent to the atmosphere when you use a blow through set-up because the air that you discharge is not metered air...With a draw through you have to recirculate it due it being metered already...
Facebook
Google+
Old May 28th, 2008, 08:30 PM   #10
HMUSN's Avatar
iTrader: 9 reviews
that's what I meant by "natural aspiration" into the atmosphere.. I was along the same lines I just worded wrong.
Old May 28th, 2008, 08:30 PM   #11
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
Also the Maxflo Race Bypass Valve is alot bigger then the mini-bypass...
And you prolly wont run enough boost to actually use it...Its for higher boost apps...
You can use a BOV or the mini-bypass and will be fine...The stock bosch valve is fine for up to 10#'s...
Facebook
Google+
Old May 28th, 2008, 08:46 PM   #12
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
How are you guys recirculating with the bypass? Mine is routed to my powerpipe but the openings are different sizes so the hose keeps coming off. It's like a 1.75" to 1.25" opening and I can't find any hoses that are that size.
Vortech V2 Si
Old May 28th, 2008, 08:48 PM   #13
HMUSN's Avatar
iTrader: 9 reviews
I'm not running one at the moment so I'm doing some research before I buy one.
Old May 28th, 2008, 08:53 PM   #14
1999 Mustang GT
I have the maxflo bypass. Where does it say it's for higher boost apps?
Vortech V2 Si
Old May 28th, 2008, 09:05 PM   #15
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
Mine is recirculated to the powerpipe...Get a bigger nipple welded on the powerpipe bung...
Maxflow bv57 Bypass ValvesThe new billet aluminum bv57 Bypass Valve flows 1300 CFM@10 PSIG. It features a large rolling diaphragm configuration with –4 AN signal hose connection and dual filtered vents that allow for quick valve response. The valve head attachment method provides valve articulation for perfect sealing to the mechanically retained valve seal.
Maxflow Mondo Bypass ValvesHigh-flow Mondo Valves (550+ CFM@10 PSIG) are recommended for applications creating more than 12 PSIG and are mandatory for any system using a cog drive belt. These units can be adaptable to all types of supercharged and turbocharged installations, mounted at any angle.
Maxflow Racing Bypass and Blow-off Valves
Our Maxflow Racing Bypass/Blow-off Valve flows 320 CFM@8 PSIG and features a compact design that is ideal for imports and others with tight engine compartments. These units will retrofit to standard HKS/Greddy style mounting pads and out performs anything its size.
Standard Bypass ValveSpecifically designed for street applications. Eliminates compressor surge and reduces heat soak in the discharge tube. Recommended for vehicles running 6 to 12 PSIG. Both inlet and outlet mate to a 1" hose.
Vortech Engineering: Air Components
Facebook
Google+
Old May 28th, 2008, 09:21 PM   #16
1999 Mustang GT
It says the Mondo is for higher boost, not the Race.
Vortech V2 Si
Old May 28th, 2008, 09:29 PM   #17
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
here is mine just added a C&L upper plenum on as well
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old May 28th, 2008, 09:31 PM   #18
1999 Mustang GT
Can you tell me where you got your parts? Is it routed back to the powerpipe? If it is what size hose did you use going to the pipe?
Vortech V2 Si
Old May 28th, 2008, 09:39 PM   #19
2001 mustang gt
so can i use say....Maxflow Mondo Bypass Valves, that 1 and still be ok for like 9 psi? i want to run anything that will ge me into 500+, but for right now im looking for like 390+ with intercooler. just wonndering will that take 15 psi pretty safely?
Old May 29th, 2008, 12:29 AM   #20
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Is the Vortech mini-bypass louder than the stock bosch that comes with the Vortech kits? just wondering... I love that little sound it makes when shifting during high boosts just wish it was louder lol...
2004 GT Boosted by Vortech
Threads Similar to: vortech mini race? is this it???
will i beat a 2006 mini cooper S in a race? nba1341 The Clubhouse 202 September 6th, 2007 11:27 PM
