If car was running lean...
Old May 28th, 2008, 09:56 AM   #1
smokeshow's Avatar
smokeshow is on a distinguished road
if my car was running lean would the engine light come on and give me a code saying it was running lean?
Old May 28th, 2008, 10:14 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
depends on why it was running lean.
Old May 28th, 2008, 06:08 PM   #3
smokeshow's Avatar
well if it was tuned by a diablo predator, and had a custom email tune put into the car, and say it was running lean, would it give me the engine light.
Old May 28th, 2008, 06:11 PM   #4
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
It can... read the code and find out
Old May 28th, 2008, 06:13 PM   #5
HMUSN's Avatar
iTrader: 9 reviews
you can hear it running lean.
it sounds kinda like popcorn .. let off the gas if you hear that sound and throw a higher octane in it.
Old May 28th, 2008, 06:16 PM   #6
Penetration before detonation
suprajay79's Avatar
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
suprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to all
You can also retard your timing a few degrees (4-6). Worked with mine
Originally Posted by 65eatsrice View Post
what better way to be woken up
Originally Posted by Jakashh View Post
a blowjob
Military Crew E-5/SSgt
White Mustang Crew Member #5
315s Crew Co-Founder
Old May 28th, 2008, 06:18 PM   #7
HMUSN's Avatar
iTrader: 9 reviews
^true story.
calling your timing belt a retard usually works too.
Old May 28th, 2008, 06:24 PM   #8
suprajay79's Avatar
2001 Mustang GT
a blowjob
Old May 28th, 2008, 07:09 PM   #9
Ugmul's Avatar
Ugmul is on a distinguished road
ya It will throw a code, belive it was P1131, mine threw it this weekend. Injectors and fuel filter were dirty, cleaned um up, reset the code. 80miles later hasnt come back.
Old May 29th, 2008, 09:56 AM   #10
smokeshow's Avatar
Well mines not making any detonation or pinging sounds, nor is it throwing an engine light or any codes. The only noise my motor makes is the typical mustang tick. The only reason I was asking is because sometimes theres white smoke comming out of my tail pipes, mind you I have an offroad prochamber and longtube headers so that may have some affect on that. But it could have been the temperature the other day, last night after I washed my car it was around 16 degrees celcius and it wasn't smoking so thats more then likely what I think is causing the smoke. Its not like the smoke is that bad anyways, its not like blasting out.
Old May 29th, 2008, 09:58 AM   #11
HMUSN's Avatar
iTrader: 9 reviews
it's probably just the O/R pipes. I'd check your coolant level just to be sure.
Old May 29th, 2008, 12:57 PM   #12
smokeshow's Avatar
Coolant levels fine, I'd say its alright. Ill just keep driving it.
Old May 29th, 2008, 01:23 PM   #13
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
M0T0PSYC0 is on a distinguished road
the white smoke is typical, my 01 and 99 do it oo depending on the temp and humidity
99 forrest green vert:
-Diablosport Predator & Tune (removed for cheap gas use)
-Motive 3.90 gears
-MRT Catted H
-Flowmaster American Thunder catback
-Eibach Sportlines
-Tokico D-Spec shocks & struts
My Garage
Old May 29th, 2008, 01:46 PM   #14
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
If it's tuned too lean it will not throw a code, as the PCM has been programmed to think that the lean setting is the correct AFR. It will only throw a code if it runs leaner than it was programmed to run--this is true in both closed and open loop.
White smoke if the outside temperature is 55° or better is generally a sign of coolant getting into the combustion chamber. If below 50° (depending on RH%) it could be just the normal water vapor that's a by-product of combustion.
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Old May 29th, 2008, 04:43 PM   #15
Trick Tuners's Avatar
KB'd GT
It totally depends on the maf curve. If its off on the low end by more than 25% it will throw a code. At WOT there is no way to tell without a wideband and it won't throw a code.
Old May 30th, 2008, 11:37 PM   #16
smokeshow's Avatar
Alright, I'm going on that its just the temperature because I checked it today and it was a nice day and no smoke or nothing. I'd get it dyno tuned but the nearest dyno is roughly a 10 hour drive away. Thanks anyways though.
Old August 20th, 2008, 06:12 PM   #17
Look Ma! My First Post!
Domsgirlie is on a distinguished road
Unhappy
Oxygen sensors are reading lean
Took my 03 Mustang to get it checked out today because the "check engine" light came on. The car doesn't feel to be running smoothly and feels like it's going to stall at stops (sometimes). Said the oxygen sensor are reading lean
The guy said the engine is either running lean or the sensors are not working and they need to run another test to see exactly what it is.
Any suggestions on something I can do on my own without taking it for the test?
Old August 20th, 2008, 06:54 PM   #18
2000 GT
is it only saying one side is lean? or throwing a code? Swap o2s, put the left in the right and right in the left bung. If the code follows replace both o2's (other one will be close behind).
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old August 21st, 2008, 03:24 AM   #19
cliffyk's Avatar
What code is being thrown? There are 7 or 8 "lean" related codes, only 2 of which indicate a bad O2 sensor. Most are a working O2 sensor reporting some other problem...
-cliff knight-
My Mustang
Old August 21st, 2008, 10:13 AM   #20
JMack's Avatar
2000 V-6
JMack is an unknown quantity at this point
+1 ^
HMUSN - the timing belt retard comment was epic...
Threads Similar to: If car was running lean...
car running lean.... need immediate help 99v6stang V6 Mustangs 59 April 29th, 2008 06:15 PM
Car keeps running lean nicklo 5.0 Mustangs 8 January 30th, 2008 12:50 AM
Running Lean ROUSHME661 V6 Mustangs 22 November 30th, 2007 02:47 PM
RUNNING LEAN !!!! 97MUSCLESTANG Modular Mustangs 6 March 5th, 2007 10:03 AM
My Car Is Running Too Lean, How Do I Fix It? SPEEDRACERCHICK02'92' 99-04 10 December 14th, 2006 12:54 AM
