guage switch? need help with reverse glow gauges!!!!!!!!!!
LinkBack (1) Thread Tools
Old May 29th, 2008, 01:42 AM   1 links from elsewhere to this Post. Click to view. #1
94pacecarSVT's Avatar
11.2@122.36
94pacecarSVT is on a distinguished road
Send a message via AIM to 94pacecarSVT
the only part on my gauges that glows is the needles and sometimes when i turn it headlights on the gauges will glow for a second and then stop glowing. i was lookin around in my car tonight and found a switch that has a knob that turns and says min on one end and max on the other, and theres a switch that says blue on one end and green on the other...does this have anything to do with my gauges?? if anyone can help me get em working that would be greatly appreciated. thanks.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.
www.rk-collection.com
Old May 29th, 2008, 01:44 AM   #2
2003 Mustang GT
03TropicGt is on a distinguished road
that knob controls how bright or dim they are, and the green/blue buttons change the color. or so its suppose too lol
Old May 29th, 2008, 01:45 AM   #3
2003 Mustang GT
sounds like a bad connection though if it only works sometimes, possibly a bad ground
Old May 29th, 2008, 01:49 AM   #4
11.2@122.36
how do i fix it? i've never messed with gauges before, how do i find where the ground is?
Old May 29th, 2008, 01:53 AM   #5
2003 Mustang GT
honestly ive never really messed with glow gauges but if the needles light up thats from the actual light in the cluster which is wired all into your parking lights. i believe the reverse glow gauges are an electroluminesent panel which would have their own power source. trace that knob/button wire and see were it goes, that should lead you to the problem
Old May 29th, 2008, 02:01 AM   #6
11.2@122.36
but i dont think its the switch thats messed up, but ill try that and see what i find. im just afraid im gonna take somethin off and not be able to get it back on right.o well i always get stuff back together. we'll see. thanks for the help man.
Old May 29th, 2008, 02:07 AM   #7
2003 Mustang GT
no its not the switch...............im saying the switch controls the power lighting the gauge face. so therefore if you follow those wires youll find a bad connection or something along that line, you know?
Old May 29th, 2008, 02:13 AM   #8
11.2@122.36
oh ok yea i see what your sayin. thanks
Old May 29th, 2008, 02:18 AM   #9
2003 Mustang GT
np
Old May 29th, 2008, 02:55 AM   #10
11.2@122.36
ok i took the gauge cluster out and removed the plate under the steering column so i could see the wires better. theres two white wires connected on either side of the bottom of the gauge cluster that run into a little blue box behind the knob, and that box is connected to the blue/gray wires on the switch that i mentioned. other than that i dont really know what im lookin at under there. i found the grounds but i cant link em to anything that i can recognize...
Old May 29th, 2008, 03:09 AM   #11
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Mine did the same thing.. i need a new switch because it was soldored bad and it pulled out one of the pins.... So if anybody knows where to find one would be awesome :p
But i would check to see if the switch wires are all tight, have the gauge on and play with wires (gauge and elsewhere).
Old May 29th, 2008, 01:43 PM   #12
2003 Mustang GT
yes there could be a bad soldering problem inside the switch but if you can try taking to trim panel off around the cluster so you can take apart your headlight switch, the power might be running there and it could have came off, or it could be running to the fuse box
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/73268-guage-switch-need-help-reverse-glow-gauges.html
guage switch? need help with reverse glow gauges!!!!!!!!!! This thread Refback May 29th, 2008 10:12 AM
Threads Similar to: guage switch? need help with reverse glow gauges!!!!!!!!!!
Reverse Glow Problem sjr56 99-04 6 May 22nd, 2008 10:18 AM
Charcoal/Black El-Glow gauges Archy88 Visual 7 October 11th, 2007 01:31 AM
help with a/c reverse glow WeCircleTheProblem Visual 4 September 8th, 2007 11:35 AM
Glow Shift Gauges? Garhfer 99-04 2 June 16th, 2007 12:18 PM
Glow Shift Gauges jerb43 Audio/Video 0 October 25th, 2006 06:04 PM
