Transmission leak
Ok well i have a 4r70w and its been leaking for some time now, i thought it was the trans pan gasket so i just recently replaced the gasket as well as the filter.... it needed it.. so tonight i noticed that there was a couple of spots of trans fluid on the ground....
Ok question is does the auto dipstick tube have an O ring or does it just press into the trans housing???.....cause it looks a lil wet from around that area.... Any info would be great!!! Thanks |
anyone know if the trans fluid dipstick has an O-ring or not???.... Thanks!!!
04 Mustang GT
pretty sure its just pressed in to the housing, not sure though. A trans leak could be numerous things causing the problem. It could be early signs of the torque convertor going...input shaft seal...pump starting to go....or something else. Jack up the front of the car, start it up, then try and get under there and see exactly where it is leaking from. I just blew out the input shaft seal on mine, its definatly not pretty and will put you dead on the side of the road.
Threads Similar to: Transmission leak
| Transmission Leak | Katen | Classic Mustangs | 15 | January 29th, 2008 12:50 PM |
| Transmission Leak? | 05MUSTANG4.0 | V6 Mustangs | 6 | September 3rd, 2007 06:10 PM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 04:46 PM |
| transmission leak | 69fastback | Classic Mustangs | 2 | February 21st, 2007 10:39 PM |
| transmission fluid leak | 87vert | 5.0 Mustangs | 6 | January 8th, 2006 11:41 PM |
