Is this COP in need of replacement?
Old May 29th, 2008, 03:21 PM   #1
whtpny's Avatar
whtpny is on a distinguished road
Send a message via AIM to whtpny
as title says.. view photos plz..
i have linked because the images are hi resolution:
http://i30.tinypic.com/7hqw.jpg
http://i32.tinypic.com/160v7sw.jpg
Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Magnapacks
WhtPny's Videos
Old May 29th, 2008, 03:41 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
is it making the car run bad. The best way to tell if your car is having probs with the cops start the car and listen to how it runs with the hood popped. And then unplug each coil one at a time and listen to how it sounds when each one is unplugged. And make sure you plug it back in before you unplug the next one. If each time you unplug one the car sounds like its missing for all 8 then the cops should be fine. If you unplug one and you don't hear a change at all then it could be bad
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 29th, 2008, 03:47 PM   #3
whtpny's Avatar
thanks man.. ill try that tomorrow probably.. i just decided to change my plugs but changed my mind to regap them because they dont look too bad so far.. just occasionally under mild acceleration ill feel a little something like a miss.. i haven't done the dollar bill on the exhaust tips trick either.. it's not running *bad* really it just doesn't feel like it's running as good as it could be.. after this scenario ill probably be trying the fuel filter
on a completely and totally different topic.. does anyone know why my negative battery terminal keeps building corrosion even after i clean it all off.. a couple weeks it's back just as bad or worse?
WhtPny's Videos
Old May 29th, 2008, 03:48 PM   #4
MM's nicest mod, :)
get a new terminal
Old May 29th, 2008, 07:19 PM   #5
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
M0T0PSYC0 is on a distinguished road
whats that? i havent heard of it before
99 forrest green vert:
-Diablosport Predator & Tune (removed for cheap gas use)
-Motive 3.90 gears
-MRT Catted H
-Flowmaster American Thunder catback
-Eibach Sportlines
-Tokico D-Spec shocks & struts
My Garage
Old May 29th, 2008, 09:42 PM   #6
whtpny's Avatar
i read it on here.. you crank the car and let it idle and take a dollar bill and hold it at hte top of the exhaust tip so that the bill hangs down in front of the tip.. it should move in a regular pattern.. if it's kinda random then you have a misfire.. those arent the direct words but it's basically paraphrased.. i forget who posted it. lol
WhtPny's Videos
Threads Similar to: Is this COP in need of replacement?
What NOT to Say to a Cop TheBusher The Clubhouse 2 March 26th, 2008 07:26 PM
Dumb Cop Red87DropTop The Clubhouse 42 September 24th, 2007 03:53 AM
Good Cop, Bad cop HMUSN The Clubhouse 4 June 27th, 2007 02:01 PM
Cop radar. where to get one Timmano V6 Mustangs 65 May 4th, 2007 10:57 AM
wierdd cop FastBack71 Modular Mustangs 37 February 22nd, 2007 06:04 PM
