LinkBack (2) | Thread Tools |
#1
MM's nicest mod, :)
First time racing tips look here
Ok, i'm a asshole so the asshole no longer has knowledge to put out
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS Last edited by White99stang; October 30th, 2008 at 02:59 PM. |
MM's nicest mod, :)
Now for you drag radial guys
Same applys for setup except bring the rear tire pressure down to about 16psi. Drive thru the water box stopping the rear tires in the water. Spin the tires over a couple of times getting them wet and then pull forward till your back tires are right on the edge of the water box. Put the car is second gear and bring the car up to 5500 rpms and then dump the clutch while hurrying and putting you foot on the brake. You shouldn't need to mash the brake pedal to the floor. You don't need to do a john force style burnout and its not a burn out competition either. Just sit there holding the rpms steady at say 5k rpms for about 7 seconds or so or until you see enough smoke where the rear is kinda cloudy. then let off the gas and do the same as above for pulling up to the line. Bring the rpms up to 5k to start to see what it does. You can try dumping the clutch too see what happens and that all can be adjusted in the next run if it spins or bogs down. If it spins the bring the rpms down, if it bogs then bring the up in about 300rpm increments. And then the rest goes with above for the rest of the driving part
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS Last edited by White99stang; October 30th, 2008 at 03:00 PM. |
Nice writeup! Btw, why should you remove your front sway bar, and isn't 45 PSI a bit much for street tires that say they should hold 32 PSI?
![]() Current mods:
MM Bullitt Crew Founder and Member #1
MM's nicest mod, :)
well the tires i had said max psi was 44, and less rolling resistance with them aired up all the way. Front sway bar keeps the weight from transfering, plus its 18lbs on the front that is not needed
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
MM's nicest mod, :)
And trust me dude everything i put in there works, i know from experience. If i can run a 13.8 with those tips bone stock and then consistant 13.6's after alot of practice and then 13.2's with just fats and skinnies, drag radials, shifter and catback i think its good advice.
Well I'm too lazy to remove my front sway bar, and I already knew about the tires, but I was wondering why you had them set so extreme lol. I guess just max out the front tires and set the rear to 22 PSI. Everything else sounds perfect, I can't wait 'til my first time on the drag
. After that, it's time to hit the track!
![]() Current mods:
rep for a good right up its actually very helpful and useful advice if you pay attention to it and keep practicing it.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
MM's nicest mod, :)
uh think mine is a little better there weinis
WHOOP!
7.44@95 (1/8)
![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I wish I would have seen this post earlier....
![]() Buy my: Nitrous Accessories Diablosport Programmer In The Classifieds |
2003 Mustang GT
12.78@106.44
nice write up white. very helpfull.
Great write up white
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
1999 Mustang GT
Thank You. Its about time some one finally did this. Im getting tired of hearing the same questions on every forum from every person! You just gained major street cred in my book! lol
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears 5.4 4V coming soon |
1997 Mustang Cobra
1/8 - 8.89@86mph
![]() iTrader: 1 reviews
I knew this from asking you my 1st time way back when but I was soooo nervous last time that I spaced out the font tire PSI and the front sway bar removal... but oh well theres always next time...
![]() Modifications and pics in my Garage... Reps Appreciated!
1997 Mustang Cobra
1/8 - 8.89@86mph
btw good write up man!!
Penetration before detonation
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
Nice writeup White. You pretty much answered my past three threads! Good way to shut up newbies at racing like me. Awesome info!
Pig Romancer
2003 GT
300.32@5.02mph
if this is irrelevant just tell me. how much of a difference does the extra weight in a convertible actually make when you're launching and racing theoretically perfect? I've noticed that on the 8th mile I'm getting beat by stock coupes. on the quarter those same cars are a fender behind me. I've got some work to do on my launch though, this write-up is going to be my new bible for that, but is it hopeless in the convertible without extra work?
MM's nicest mod, :)
its all about weight man, a vert weighs alot more so of course to get more weight to go fast as something that is lighter you need more power
Pig Romancer
2003 GT
300.32@5.02mph
I know I'm about 200 or 300 or so pounds heavier than the coupes right? I've got intake, plenum, throttle body, tb spacer, off road x pipe, flowmaster catback, sct 4 bank...I can take the stock coupes, but not as easy as I'd like...my launching helps a lot though, I've realized that a race can be won by a great launch against a terrible launch.
I haven't tried this on my drag radials but I'm not sure if I'm daring enough for a 5000 RPM launch.
Great advice - I needed some tips. I'm running a full bolt-on 96 Cobra with drag radials (M/T) and adjustable suspension, my best 60' is 1.89. Could this be lower? Fastest pass is a 13.49.I've got 4.10s and a rear end girdle, I'm afraid such a high launch will destroy something even though it's a little better than stock? I know racing is breaking and I'm not afraid too, just not sure if that's too much. I shift around 6500. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/73339-first-time-racing-tips-look-here.html
| » First time racing tips look here A Side: What The World Is Saying About A Side | This thread | Pingback | June 7th, 2008 09:09 PM | |
| First time racing tips look here | This thread | Refback | May 29th, 2008 05:45 PM | |
Threads Similar to: First time racing tips look here
| first time drag racing | Toph6888 | Drag | 2 | April 16th, 2008 10:02 AM |
| Pypes Mid-Muffler install time / any tips? | tribaltek | 2005 - 2010 | 15 | March 21st, 2008 10:33 AM |
| First Time At The Track (Racing) | MyGT | Drag | 20 | November 29th, 2007 08:42 PM |
| New member first time poster long time fan | kpmorris | New Members Introductions | 14 | August 20th, 2007 12:53 AM |
