Another Cam Question
Old May 30th, 2008, 02:20 PM   #1
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
I have been searching and reading old threads for 2 hours now. More confused now then before.
I want to install cams in my 01 gt 2v n/a can I run stage 2 cams with no ptv issue or not? Can I use stock springs or not ? also its an auto
If not I will run the stage 1's or something else someone recomends. how much of a sound difference at idle is there between the 2. I want something to perform well and sound good at idle.
or is there a custom grind that someone has experience with that they would recomend for me.
any help would be greatly appreciated.
Thanks John
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old May 30th, 2008, 05:13 PM   #2
shortskirtsnturbos is on a distinguished road
I totally understand where u are coming from wen u say u didnt learn much by searching.. It doesnt usually help me either.. I would also like to know wat people suggest for you u.. cuz i dnt know a damn thing bout cams..
Old May 30th, 2008, 05:23 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
i am confused, you say you want n/a cams but your sig says you have a blower.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 30th, 2008, 06:15 PM   #4
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
If you plan to run N/a Hitech motors stage 2 make about the best power and drivability of all the shelf cams. If you plan to run a custom grind you may find that changes down may change the power output. I have spec'ed out dozens of cams for NA combo's and had success, the people that change things later are the ones that usually end up ordering another set. Heads, headers, torque convertors, intake systems, ect. can make or break a custom cam. Good luck on your choice.
Be sure to take the time to degree the cams and check all your clearances. The people that have PTV are the ones that skip this important step...
Old May 30th, 2008, 09:27 PM   #5
johnr2001's Avatar
2001 GT
its not for the vortech car, I have a couple stangs. someone else just told me the same thing buy hitech stage 2 and when properly degreed right will have no ptv issues.
443 RWHP/ 386 TQ
Old May 30th, 2008, 11:13 PM   #6
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
we stuffed some CMS stage 2 N/A cams in a car about 2 wks ago along with comp springs and had no PTV.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old May 30th, 2008, 11:30 PM   #7
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
+1 and hitech stage 2 claims they don't have a ptv issue
So I don't focus on my mistakes. What keeps me going? I look in the mirror and I am PROUD that I will do WHATEVER it takes to provide for my family. Whatever it takes.
Old May 31st, 2008, 02:15 PM   #8
01GTstang's Avatar
2001 MustangGT 2003 Cobra
GT-13.079 @ 104.69 Cobra-12.60 @ 111.11
01GTstang is on a distinguished road
Send a message via AIM to 01GTstang
ummm what are hitech cams? brand? or type of cam someone makes?
2001 GT: For Sale, low 13s
2003 COBRA: 12.11@116
Old May 31st, 2008, 03:54 PM   #9
Hitech Ford 4.6 / 5.4 2V N/A Stage 2 Camshaft [Hitech2061] - $599.00 : Hitech Motorsport Inc, Performance EFI Tuning / EFI Dyno Tuning Experts - Elk River, Minnesota - Midwest Region
You only have to worry about ptv if you don't degree tha cams. Over and over say ptv like it is the cam manufacturers fault, it is never the cam it is failure to check clearances that lead to the cause.
Old May 31st, 2008, 03:59 PM   #10
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
either hitech 2s or cms 2s, neither will haveptv issues
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old May 31st, 2008, 04:40 PM   #11
johnr2001's Avatar
2001 GT
can I run the hitech stage 2 in my auto without a stall ?
443 RWHP/ 386 TQ
Threads Similar to: Another Cam Question
Cam Question 2BTAMED 99-04 43 May 7th, 2008 10:34 PM
Another Cam Question usafimj 2005 - 2010 3 March 4th, 2008 07:11 PM
cam question blue03mach1 99-04 24 February 26th, 2008 02:18 PM
cam question sixpack 5.0 Mustangs 6 September 18th, 2007 05:50 PM
Cam Question thewayshemoves 99-04 10 December 28th, 2006 09:47 AM
