need sct help
Old May 30th, 2008, 10:51 PM   #1
2003 Mach 1 Mustang
kevin86freeman is on a distinguished road
need sct help
ok so i bought this sct xcal2 of someone and i downloaded the liveload and what not. haven't been able to put it on my car cause its still getting some body work done. Well anyway i couldnt wait to plug it into my car so i pluged it into my computer to see the menu. The liveload poped up and i was looking at it and it said xcal2, v1.14 state Prog:stock. Read Successful...
so did i just get jacked or something?
M.M. MACH1 CREW
Member 7
Old May 30th, 2008, 11:28 PM   #2
2003 Mach 1 Mustang
bump?
M.M. MACH1 CREW
Member 7
Old May 31st, 2008, 02:50 AM   #3
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
depending on model of the xcal it may only be loaded with a custom tune for previous car. You might have to cough up a few $ to get your own tune. It says its stock, so you should be good to go with it. Also while its plugged into the computer you should be able to scroll through the screens to see what if any tunes are installed into the device. You can do an email tune from a few companies for around $40 or so.
Old May 31st, 2008, 02:51 AM   #4
Moderator
Did you make sure that the tuner was unmarried from the previous owners car?
Old May 31st, 2008, 04:44 AM   #5
2003 Mach 1 Mustang
well is there anyway of knowing without asking the guy that i bought it from?
M.M. MACH1 CREW
Member 7
Old May 31st, 2008, 04:47 AM   #6
2003 Mach 1 Mustang
who would i go to if i wanted a custom tune?
M.M. MACH1 CREW
Member 7
Old May 31st, 2008, 07:21 AM   #7
dude496's Avatar
04 Mustang GT
if its says stock on liveload, it should be unmarried.
As for getting a tune you can contact joe at trick tuners for a custom tune. If you have serious mods, you will either need to go to a dyno or get a wideband setup and datalog for email tuning.
Threads Similar to: need sct help
i need an SCT gooberhead320 The Clubhouse 7 April 29th, 2008 09:19 AM
SCT Predator or SCT Livewire RX Bandit 2005 - 2010 7 July 3rd, 2007 08:40 AM
SCT X2 MnrlGry01gt 99-04 2 June 26th, 2007 10:21 PM
SCT help please Max02420 Audio/Video 23 January 3rd, 2007 09:37 AM
