Friction Modifier?
Old November 2nd, 2006, 10:23 PM   #1
4.6gtmarine is on a distinguished road
Friction Modifier?
there is a humming noise coming from the rear of my 02 gt, is this bearings or a lubricant problem? if it is bearings how much does this usually cost?
Old November 2nd, 2006, 11:46 PM   #2
11.21@123 -150 shot
orangeRcode is on a distinguished road
This is hard to diagnois with limited info. How many miles on the car? Is it the stock gears or have you had aftermarket gears installed? Have you checked to ensure the differential is full of oil? You wouldnt just add friction modifier, it would generally be added with new gear oil. Give us some additional info so we can try and help you out.
Old November 3rd, 2006, 12:23 AM   #3
friction modifier
okay, here it is 50,500 miles with no gear change. it doesn't seem to change noise when in turns as this would be bearings i think. it really only makes noise at speed like 25 or 35 mph. any ideas? should i change the gear oil in the rear?[/code]
Threads Similar to: Friction Modifier?
Centerforce Dual Friction Clutch Install SilverStang03 99-04 8 September 21st, 2007 02:01 PM
Should I add friction modifier with Valvoline gear oil 96BluePony1261 Modular Mustangs 5 March 1st, 2007 05:55 AM
Friction additive? OTreborO General Tech 7 April 11th, 2006 03:51 PM
