'00 Crankshaft Position Sensor
2000 Mustang 4.6-Checked for voltage at crankshaft position sensor and have none. Key on, engine not running when tested. Any ideas?
is it a vrs or a hall-effect? in other words, are there two or three wires
It is a 2 wire.
My new thought is that maybe it's the PCM. There's 3 or 4 coils that intermittently get spark. PCM reader says 3 bad primary coils. I don't think 3 coils would go bad at once. That leads me to the PCM. Help please. I don't want to buy this expensive part unless I am pretty sure. I took the coils not firing, switched them with the ones that do fire, and they worked. So I know it's not bad coils.
check it with the car running. You are going to wanna but it on A/C voltage because it's a reluctor wheel sensor so it supplies an analog signal to the PCM but if the crankshaft is not turning then it is not going to read voltage. By the way make sure you check the plugs. It could be something as simple as a plug thats shorting every now and then. Don't assume it is your PCM just because it is intermittent.
i think when he says the engine is was not running when tested he meant period...like it will crank but not fire maybe? if the crank sensor is bad that will cause a no start
Threads Similar to: '00 Crankshaft Position Sensor
| maf position | Fastpitchdad | 5.0 Mustangs | 3 | June 10th, 2007 10:56 AM |
| P0340 Camshaft Position Sensor Circuit Malfunction | autostang03gt | 99-04 | 4 | January 14th, 2007 09:48 PM |
| 1999 4.6 cobra camshaft position sensor | lovedr79 | Modular Mustangs | 8 | January 2nd, 2007 10:10 AM |
| Throttle Position Sensor And Power Adders | stangempire82 | 99-04 | 1 | November 19th, 2006 08:14 PM |
| P0340 camshaft position sensor | yellowfever | 99-04 | 1 | October 9th, 2006 11:19 AM |
