2001 Mustang GT Convert.
Blow-by!?!
i had a problem with oil getting into my intake manifold..then back into the combustion chamber and burning up and all that..
ok well i figured out somethings wrong with my car......guess heads and cams where drawing a pretty good vacuum...the PCV system was sucking in oil and air thru the valve covers right back into my intake...thats why i was getting a shitload of oil into my intake and cylinders... so i blocked off the CAI spot and spot on the plenum where the PCV system tubes go into and i let the PCV valves just breathe into the air...well it seemed to run better and cleaner...im still getting smoke out the exhaust... but heres the weird thing now the pcv valves are BLASTTINGGG out white smoke (they are venting to the air)...really bad on the drivers side...i have no idea what would cause this...maybe just from a shitload of oil getting everywhere and it needs a long time to burn off..bc i got her nice and hot today and it just still kept comming out... and im still getting a weird tick thats not in the heads/headers/front cover...but u mainly hear it in the intake manifold....used a stethoscope and narrowed it down... a guy on another forums said to do a compression test and see if your rings are shit causing all the blow by and thats why all that white smoke is flying out of your valve covers... ANY input at all...anyone run into this...thanks .... i really dont want to be doing a bottom end right now...
2001 Mustang GT Convertable 4.6 UNCLE SAMS AMERICAN MUSCLE!!! www.myspace.com/unclesamswny mods in vid http://youtube.com/watch?v=U0ZrgSvJjgE club vid http://youtube.com/watch?v=Cocee108Kcw |
the spot on the plenum is not a vacuum..
put the line back in and run a catch can. the pcv IS a vacuum and needs that line.
lol i put my finger up to it and it sucks it...so im pretty sure its taking vaccum
and that doesnt explain all the white smoke comming out of the valve
yea I'm
I mis read your post. it is a vacuum. regardless ya need to put that line back. the vacuum is what cools the system. a catch can is a normal mod and a good idea when having blow-by. I had a similar issue on my 91 and it was actually causing pcv blowout. I lost like 4 quarts of mobil1 FTL.
yea but ill be emptying it everyday...i dont think thats normal....plus its a lot of white smoke that will go back into the motor..that dont make sense to let that go in
If your having that much blow by you need to have a data log done and see what's going on. a compression test is also a great idea.
yeah...i think my rings or something is shot
that's just an excuse for forged parts.
Proud American
werent you the one that just put in "stage 2" cams from comp? HOw did it turn out?
yeah lol havent u read...having some issues
1999 Mustang GT
13.8
if your rings are shot enough to be causing that much blowby than you would probably feel like your car doesnt have any power. I dont know what would be causing it though, my drivers side tube from the cover to the intake tube seems to suck up oil too, but I dont really burn any oil or have any smoke coming from anything. But you really do need to at least have your pcv hooked up for the computers sake, it will start adjusting shit it dont have to to make up for the smog induction (ok, making new phrases here) to work correctly. Ive noticed before from unhhoking those my car starting acting wierd, unhhoking to test issues i used to have.
99 forrest green vert: -Diablosport Predator & Tune (removed for cheap gas use) -Motive 3.90 gears -MRT Catted H -Flowmaster American Thunder catback -Eibach Sportlines -Tokico D-Spec shocks & struts My Garage |
My car is supercharged and I put the little air compressor filter tube on it to catch the blow by and it's barely got like maybe 6 drops worth of oil in it in the past like 5 months I think I put it on... so there definitely is a problem there... I would guess the piston rings, that's what causes most of the blow by especially if it isn't supercharged.
![]() 2004 GT Boosted by Vortech |
Boost gets you laid
you said white smoke? sounds like a blown head gasket or something.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
Threads Similar to: Blow-by!?!
| Blow This! | TheUNZippee! | The Clubhouse | 44 | October 7th, 2009 01:11 PM |
| Blow It Up | BWAL | The Clubhouse | 4 | December 9th, 2007 12:11 AM |
| best way to blow 3k | chrish91286 | 99-04 | 32 | October 31st, 2007 02:29 PM |
| blow off | mystang0673 | 99-04 | 0 | August 30th, 2007 11:26 PM |
| Blow By | jj2473 | 5.0 Mustangs | 7 | July 15th, 2007 12:32 AM |
