Discussing Nitrous in the 99-04 Forum. is there anything I should do to the engine before I run any nitrous? in ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 GT
Nitrous
![]() SCT chip, 4.30's, Flowmaster w/ Turndowns, Trick Flow Plenum, BBK 70mm Throttle Body, Pypes X-pipe, BBK CAI, 100 shot and nitto radials on the way.
run some 93oct and get some colder plugs and spray it. your gt can handle a 100shot no problem. you can retard the timing to be safer but you should have no problems with a 100shot
2003 GT
what plugs would you recommend?
ngk i dont know the part number for them someone else will chime in with it though
ngk or autolite 1-2 steps colder than stock. I dont know the number for the modulars.
Member #1 MM is going down the shitter fast!
id only go 1step colder for a 100shot
1997 mustang gt
8.06 at 87mph 1/8th mile on a 50 shot
ngk tr6 FTW!!!!
97 gt with 2004 pi motor,acufab intake and 75 mm bbk cold air kit,bbk long tube headers, off road h pipe,2 chamber flow, 3:73, diablo chip with dyno tune 269rwhp 301rwtq |
2000 mustang gt auto
14.0@99
autolite 103's one step colder.
13.582@97.59 @ 5800 FT
tr6s gapped at .034
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
1997 mustang gt
1999 Mustang GT
Get the NGK TR6 plugs and they do come pre-gapped, but i always double check the gaps anyways. Stay away from Autolites IMO. I wouldn't be sparaying any more than a 100 shot w/o more mods and most importantly a tune! Your gonna want to spary more once you see what it does, but DONT! Good idea is to give your other jets to a friend you can trust. Me and a friend of mine who own a camaro are giving one another our jets and then making a list of requirement detailing what we must do in order to allow the other to have his next jet size(ex. you must have a tune and new manifold to get you 150 shot). I recommend this plan to anyone getting into nitrous. Its a good way to avoid destroying your car.
BBK CAI, March Pulleys, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Steeda X2 Balljoints, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic coated LTs, BBK catted X-Pipe, SLP Loudmouth cat-back, EBC rotors |
2003 GT
that's all for 150 shot? manifold and tune? at what point do I start throwing rods through the hood and things like that?
you would be risking it with a 150shot stick with a 100
1999 Mustang GT
no... those were just some examples. I was just trying to make the point that you should stick w/ the 100 unless you plan on making some major modifications, most important being the tune. You'd need a lot more to be safe. manifold, tune, WOT, bottle heater, ignition box, the list goes on. I was just trying to share the idea of having someone else hold your jets for u. Its a very smart play!
2001 Mustang GT
14.1@97 1.9 60ft. first pass - 130 degree track
smart untill you wanna spray more so bad you just order new jets online lol
1999 Mustang GT
NO! YOU BASTARD! I never would have thought of that. now you completely FUCKED my entire safety system! i hope your happy. You can fix that shifter by yourself now you dick!
2001 Camaro z28
go with those..have you thought about which kit..i'd say NX kit..100 shot and tune and you should be fine
2001 Mustang GT(sold but not forgotten) 2001 Camaro Z28 332rwhp (on mustang dyno) -The bullshit stops once my right foot drops dont forget to REP me!!
2000 mustang GT
11.79@125
like matt said ngk tr6 gapped at .034
also even if your spraying a 100 shot, you should have a wot switch, a window switch, bottle warmer and all of the safety equipment. lots of people have sprayed a 150 shot on their stock motor and been fine, but you would have to run hihger octane and pull a tad of timing to be safe. with your 100 shot, you can eitehr pull 2-3 degrees of timing, just to be on the safe side or always run 93 octane on stock timing to be safe. some will say you can do it with stock timing and octane, but why risk it. some ave been fine, some have had bad problems. you need a window switch to control when your car sprays the nitrous (rpm), id reccomend never below 3000 rpm for a 100 shot, or a 3500 for a 150 shot. if you go below these, you set your self up for the possibilty of the fuel in the nitrous mix to puddle up in the intake, and then light off and cause a nice big explosion insdie your intake which destroys it and possibly your hood and your cia |
#19 | |
1999 Mustang GT
#20 | |
2003 GT
Street Fast 16.9@76MPH
Threads Similar to: Nitrous
| Nitrous | Stang281GT | 99-04 | 10 | February 16th, 2008 12:36 AM |
| K&N CAI, Nitrous kit, nitrous accessories | Timber | Air/Fuel | 12 | June 28th, 2007 10:35 PM |
| Nitrous anyone??? | kmjsmith | 2005+ | 11 | May 14th, 2007 07:20 PM |
| NITROUS | 93GT | 5.0 Mustangs | 9 | May 14th, 2007 02:40 PM |
| nitrous | 9stang1 | 5.0 Mustangs | 29 | January 22nd, 2007 08:48 AM |
