differential
Old June 8th, 2008, 04:29 AM   #1
Mike73's Avatar
Mike73 is on a distinguished road
differential
My rear end of my Mustang GT '01 sounds really bad. Since one week it makes a noise. I know the best way is to recondition it but I just wanna make sure there's enough oil in it. I don't know how to check the level of it.
Anybody knows how?
Thanks for your help
Old June 8th, 2008, 09:08 AM   #2
BREEZY B's Avatar
2011 Mustang GT
12.89@111
BREEZY B is on a distinguished road
Theres a plug in the casing you have to take out and then you just stick your finger in the hole and make sure the oil is right at the edge of the hole.
2011 Mustang GT Auto Bone Stock
Old June 8th, 2008, 05:33 PM   #3
Mike73's Avatar
I'm not talking about the transmission, it's the rear axle. There's no plug or bolt to take out. This thing is completly closed like I saw.
I really don't know where to look???
Old June 8th, 2008, 05:39 PM   #4
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
there isn't a drain, you have to remove the cover to get the fluid out. I doubt its a fluid problem though.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 8th, 2008, 11:20 PM   #5
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
its on the driveshaft side. at the top. it's a 3/8 square head bolt. just look on the top of the differential
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old June 8th, 2008, 11:22 PM   #6
Proud American
MustangMatt96GT's Avatar
Thats the fill point, but like White said, to drain it, you have to pull the rear cover off...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old June 8th, 2008, 11:24 PM   #7
SteviGX's Avatar
yeah. But thats how you can check to see if you have a good amount of fluid. stick your pinky in there and if you get some nice 90W then your good. if not fill it up.
Old June 8th, 2008, 11:42 PM   #8
Honeybadger is Crazy
futureMACH1racer's Avatar
2008 F-250 Super Duty
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Could be the bearings going out.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old June 8th, 2008, 11:56 PM   #9
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
68 dlxcoupe is on a distinguished road
Send a message via AIM to 68 dlxcoupe
Tru Trac Time
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old June 9th, 2008, 12:14 AM   #10
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
+1
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Threads Similar to: differential
Differential? mystang0673 99-04 1 November 24th, 2007 07:01 PM
Differential 01dutchGT 99-04 15 November 12th, 2007 01:37 PM
Help! Differential flames_blue V6 Mustangs 5 February 5th, 2007 03:55 PM
Differential whitb610 99-04 5 November 4th, 2006 10:49 AM
Differential Drgnracin72 General Tech 4 September 19th, 2006 10:06 PM
