![]() iTrader: 1 reviews
hotter and ALOT louder ok?
i know my shifter is suppose to be a little noiser now but its really bad....and sometimes i here it starting to rattle...
not to mention i can feel heat coming from it and like burning my rigth leg which never happened when i was stock these problems ok? i called steeda and they said to cover the metal on the shifter with aluminum foil...and that noise doesnt matter
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
MM's nicest mod, :)
don't matter your dad is going to have to get used to driving it anyways lol
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
lol...stfu
![]() serisouly tho...that usually happen with an aftermarket shifter? and if i see that car gone im reporting him for driving without insurance lol
and my speedo is so far off when im doing like 50 it says like 90...
ima have to post a vid from like 0-150 or something (my 0-60 was like 5 seconds without even launching hard or flooring it in second)
Proud American
Sounds like the car has gears in it, if the speedo is off, and heat from the shifter is normal...
yep just put the gears in
so burning my leg doesnt mean my car is gonna break or anything and no matter how loud the shifter is its still fine cuz its shifting great rite?
Proud American
Well burining your leg isnt something thats going ot happen. You still need to put the heat sheild back on....
And noise will start going away after 300 miles prolly.
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
I didnt get any heat from my tri-ax nor a raddle. Did you make a bead rtv seal between the shifter and the tranny of the car??
Fire it up, burn it down.
the heat shield?
Proud American
The gray rubber thingy... that goes around the shifter. Its a noise and heat sheild..
i read about that and whitestang mentioned it but then i figured that was wat i spent 10 bucks on when i ordered the gasket thing to go along with it...i have the gaskey shitting above the tranmssion, then the shifter base...then i have that rubber boot followed by the metal rectangle
#12 | |
yep i got that
http://www.cardomain.com/ride/3112249 |
My shifter doesn't make any noise and I don't feel any heat either
Vortech V2 Si
1999 Mustang GT
if you cleaned the old liquid gasket off really well and applied a new layer between the shifter and gear box you shouldn't have any noise coming from there. I recommend using "The Right Stuff" liquid gasket. Its good shit! Also, im not entirely familiar w/ the Steeda shifter, but you should use loctite(red) on all the bolts that hold the the shifter in place, assuming the tri-ax is an adjustable shifter... W/o loctite it liable to come loose on you which may be a souce of some rattling/noise.
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears 5.4 4V coming soon |
so even with the gasket thing i paid an extra 10 bucks for i still need the rtv sealer?
then wtf was the point of that gasket shit
1999 Mustang GT
ive seen the shifter gasket kits online and i dunno how much faith id put in one of those, but then again ive never seen or used one. But i do know that u cant go wrong using "The Right Stuff" liquid gasket.
thanks
1999 Mustang GT
no problemo. you should be able to find the right stuff at any auto parts store. Its kind expensive(30-35$), but it usually comes in a kit w/ 2 tubes and a gun.
i dont htink im willing to spend that much lol
i dont really think thats the real problem tho....i think it mite just be the bolts for the shift stops rattling or something
Threads Similar to: hotter and ALOT louder ok?
| Ok... what do you think will b louder? | mustangmanic | General Tech | 9 | April 25th, 2008 01:37 PM |
| Even louder then a Cobra? | DeMello | 99-04 | 202 | April 14th, 2008 06:03 PM |
| i want it louder! | Blk01ponyGT | General Tech | 18 | January 27th, 2008 10:01 PM |
| Hotter at Speed | gotboost562 | 5.0 Mustangs | 2 | August 30th, 2007 08:45 PM |
| Louder, Louder, Louder | mustang1072 | General Tech | 41 | March 28th, 2007 07:11 PM |
